Up for sale are my 19x9.5 +40 (+28 With included 12mm spacers + wheel nuts or +35 with 5mm spacers) Axis Hiro copies.
They sit perfectly flush on a M35 Stagea.
The wheels have been on my car for the past 6 or so months. In perfect condition and never grazed.
Includes Falken tyres. Some wear (see photo).
Price: $999.00 Firm. I can post interstate at buyers expense.
PM or call Chris - 0423 176 774
Here are some photos of the wheels & Tyres:
Cheers.
Chris.
https://www.sau.com.au/forums/topic/371618-fs-19x95-axis-hiro/
I don't suppose you'd know how these would fit on a C34 series 2 manual at all?
I ran Enkei RP03 - 19" x 8.5", +22 and they sat pretty close to flush. I probably had another few mm to the guard edge, so a 9.5", +28 probably wouldn't fit, even without a spacer.
The 9.5" wheel is an extra 13mm wider than the 8.5" from the centre to each side (total 25.4mm). Less 6mm for the offset difference and you're still 6-7mm wider to the outside than my wheels. You'd be cutting it real close!
You'd also have to take into account any rubbing of the tyre on your suspension as the wheel is 13mm wider from the centre to the inside as well.
They'd look good though, especially with wide rubber; it would give a great stance from the rear.
I ran Enkei RP03 - 19" x 8.5", +22 and they sat pretty close to flush. I probably had another few mm to the guard edge, so a 9.5", +28 probably wouldn't fit, even without a spacer. The 9.5" wheel is an extra 13mm wider than the 8.5" from the centre to each side (total 25.4mm). Less 6mm for the offset difference and you're still 6-7mm wider to the outside than my wheels. You'd be cutting it real close! You'd also have to take into account any rubbing of the tyre on your
well. They'd look good though, especially with wide rubber; it would give a great stance from the rear.
Cheers for that. I'm still trying to get my head around what will and won't fit my car. Makes it a little harder having a manual with narrower rear track and not wanting to run spacers.
Hell yeah they'd look good but I can't be arsed with the complications.
Edited by BMX666
Bmx666, after fitting stagered offset wheels to my rs4s. I think we have same front/rear track, it's the auto that has a wider rear end then the front. I bought 18x8 +6 for the rear and +35 for the front then had to fit a 25mm spacer to the front just to fix it. And by my count. These wheels should fit depending on your height, I would do a test fit if you can. 19s would fill the c34 guards so well.
Edited by lilcrash
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
    • Hey mate, really appreciate the help. Have been looking pretty extensively myself and was certain they were retro fitted, but then ended up finding a 4 door with what looks like the same side skirts or at least the closest I’ve seen. The photos from the Offset Kings event at Sunrise 2016. https://fatlace.com/offset-kings-okayama-at-sunrise/
