Hey guys, just wondering can you wax your car straight away after polishing? or is there a time period you have to wait after polishing?
In short, yes you can.
In long, I like to polish then us an IPA 50/50mix with water wipe down to get rid of any residue, then follow up with a synthetic sealant topped with a wax for that extra depth.
Regards,
Mitch
https://www.sau.com.au/forums/topic/371652-polish-then-wax/#findComment-5925250
Yes you can, just don't wax then polish. Although if you dont polish you wont remove any swirls or fine scratches you may have on the surface.
Correct,
I would suggest you give your car a wash, claybar, and wash again then apply a decent wax.
You only need to clay bar 6 monthly at worst but most likely yearly.
These are what I would use on a budget.
Clay Bar Kit
Wax
Wash Shampoo
Regards,
Mitch
https://www.sau.com.au/forums/topic/371652-polish-then-wax/#findComment-5926300
Clay bar does wonders. After a polish the water just beads. It makes me laugh when it rains and the 33 is the only car beading 99% the time. Theres alot of lazy kunts that dont clean their cars :P
LOL! I just spent 5 hours on my 33! haha i didn't use a clay bar I used paint cleaner instead.. and mannnn does it look good.. The rain just rolled right off it today :P
https://www.sau.com.au/forums/topic/371652-polish-then-wax/#findComment-5929676
Hi,
Is it necessary to dry the car then use the clay bar? Or would it be o.k to just spray the lubricant while the car was wet and use the clay bar?
https://www.sau.com.au/forums/topic/371652-polish-then-wax/#findComment-5931711
Do you mean you clay bar after a polish?
Paint cleanser and a clay bar are VERY different a clay bar will remove all the iron particles, industrial fall out, and other contaminants where as a paint cleanser wont.
A paint cleanser will help prepare the paint for a wax or sealant helping remove oils that will hinder the wax or sealant from adhering.
Just as an FYI.
Ps check out my site the 1964 Cadillac had approx 25 hours machine polishing alone not including any thing else! www.immaculatereflections.com.au
Regards,
Mitch
https://www.sau.com.au/forums/topic/371652-polish-then-wax/#findComment-5931762
apologies for hijacking thread, but just wondering if using a clay bar will help get swirl marks out?
gave it a polish/wax over the weekend & it helped, but still got some damn swirl marks on the bonnet haha
cheers guys !
https://www.sau.com.au/forums/topic/371652-polish-then-wax/#findComment-5933316
cheers guys !
A clay bar removes contaminants and industrial fall out from your paint, it wont remove marks or scratches. Polishing is what removes that.
My other thread may help you http://www.skylinesaustralia.com/forums/topic/369354-detailing-and-car-care-de-coded/
Regards,
Mitch
https://www.sau.com.au/forums/topic/371652-polish-then-wax/#findComment-5933414
The clay bar also requires constant kneading so that the pollutants and particulate matter don't stay between the clay bar and paint...
> otherwise more scratches can be generated.
> whilst it's necessary, a lubricant can't do it all.
https://www.sau.com.au/forums/topic/371652-polish-then-wax/#findComment-5934791
I would say folding as opposed to kneading just so it doesnt confuse people. You want to fold it over so the part you were previously using is now in the middle of your "pancake shape" clay.
https://www.sau.com.au/forums/topic/371652-polish-then-wax/#findComment-5934830
    • I'm not a big fan of the Cometic gaskets either, as above the head and deck need to be like a mirror (can't remember the RA) so Kamieri sounds like a good idea.  FWIW a mate of mine hordes old motor stuff and has some blank unground Nizmo cams for one of these in his supply if random shit if you're interested.
    • This is aem disk setting in aem tuner and still 180 dgree off or ignition on exhaust cycle is it from cas it self as cas seems wouldn’t fit in cam shaft if wrong position and wiring been verified any ideas
    • Oh yeah that would work excellent. Should be the same diff housing & everything. Shoot me a text or call me 260-750-2246 -Cody
    • Oh right, I didn't realise it was your car. Please do! Makes me feel better about mine. I also have a big scrape on the front left bumper where someone presumably used the wall to guide the car into a parking spot  But somehow all the funds go towards mechanical things and the cosmetics stay forever unfinished... Interesting, I don't think I have seen it before. But after seeing @PranK's rusty roofline on the BMW I'd probably leave it alone. Wouldn't want water to get in there.
    • Thanks mate, thought you might know the answer.
