Hey guys, just wondering can you wax your car straight away after polishing? or is there a time period you have to wait after polishing?
In short, yes you can.
In long, I like to polish then us an IPA 50/50mix with water wipe down to get rid of any residue, then follow up with a synthetic sealant topped with a wax for that extra depth.
Regards,
Mitch
https://www.sau.com.au/forums/topic/371652-polish-then-wax/#findComment-5925250
Yes you can, just don't wax then polish. Although if you dont polish you wont remove any swirls or fine scratches you may have on the surface.
Correct,
I would suggest you give your car a wash, claybar, and wash again then apply a decent wax.
You only need to clay bar 6 monthly at worst but most likely yearly.
These are what I would use on a budget.
Clay Bar Kit
Wax
Wash Shampoo
Regards,
Mitch
https://www.sau.com.au/forums/topic/371652-polish-then-wax/#findComment-5926300
Clay bar does wonders. After a polish the water just beads. It makes me laugh when it rains and the 33 is the only car beading 99% the time. Theres alot of lazy kunts that dont clean their cars :P
LOL! I just spent 5 hours on my 33! haha i didn't use a clay bar I used paint cleaner instead.. and mannnn does it look good.. The rain just rolled right off it today :P
https://www.sau.com.au/forums/topic/371652-polish-then-wax/#findComment-5929676
Hi,
Is it necessary to dry the car then use the clay bar? Or would it be o.k to just spray the lubricant while the car was wet and use the clay bar?
https://www.sau.com.au/forums/topic/371652-polish-then-wax/#findComment-5931711
Do you mean you clay bar after a polish?
Paint cleanser and a clay bar are VERY different a clay bar will remove all the iron particles, industrial fall out, and other contaminants where as a paint cleanser wont.
A paint cleanser will help prepare the paint for a wax or sealant helping remove oils that will hinder the wax or sealant from adhering.
Just as an FYI.
Ps check out my site the 1964 Cadillac had approx 25 hours machine polishing alone not including any thing else! www.immaculatereflections.com.au
Regards,
Mitch
https://www.sau.com.au/forums/topic/371652-polish-then-wax/#findComment-5931762
apologies for hijacking thread, but just wondering if using a clay bar will help get swirl marks out?
gave it a polish/wax over the weekend & it helped, but still got some damn swirl marks on the bonnet haha
cheers guys !
https://www.sau.com.au/forums/topic/371652-polish-then-wax/#findComment-5933316
cheers guys !
A clay bar removes contaminants and industrial fall out from your paint, it wont remove marks or scratches. Polishing is what removes that.
My other thread may help you http://www.skylinesaustralia.com/forums/topic/369354-detailing-and-car-care-de-coded/
Regards,
Mitch
https://www.sau.com.au/forums/topic/371652-polish-then-wax/#findComment-5933414
The clay bar also requires constant kneading so that the pollutants and particulate matter don't stay between the clay bar and paint...
> otherwise more scratches can be generated.
> whilst it's necessary, a lubricant can't do it all.
https://www.sau.com.au/forums/topic/371652-polish-then-wax/#findComment-5934791
I would say folding as opposed to kneading just so it doesnt confuse people. You want to fold it over so the part you were previously using is now in the middle of your "pancake shape" clay.
https://www.sau.com.au/forums/topic/371652-polish-then-wax/#findComment-5934830
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
