  • Replies 112
my sunroof leaks.....
Wear a raincoat?
Well raining nice and heavy at the mo here( i am 15mins from lakeside) but i think it will clear.
It will still be a lot of fun come rain or shine.
A few of us northside boys will be heading directly to the track as we have a few things to finish up. what time should we be arriving at the track?
I think we have to be at the track by 4pm. ( going on what happened last time)
Trying to rig a camera in my car. if it works lok for the lovely white r33 with the pink camera on dash lol :rolleyes:
yeah we'll be there by then, just going to do pre track check on the cars now.
Happy laps is definately still on guys, have faith :nyaanyaa:
As somebody said, its looking better by the minute :thumbsup:
Yea mate 4pm we will be there
What a great arvo out, not even the slightly dodgy weather could of ruined that. hanks to the organizers and caterers and to the track staff for letting us have some fun and cut loose despite the moisture on the track.
Awesome arvo, damp track was a bit of fun in the GTR lol. Excellent to meet you rob, the 35 is absolutely mint.
My mates in the identical twin Evo's had a blast aswell.
And for those interested they have near exactly the same mods and on E85 punching out around 250-255kw. If you thought they were quick, thats why.
Thanks for making it a great success guys. Everybody behaved really well and had a tunnafun.
The next one is being scheduled for qld raceway at willowbank and will be a breakfast affair. Get outta bed you bums.
Cya there. :thumbsup:
Yeah was a great happy laps
mildly moist conditions FTW
MMmmmm I thought they were a bit quick, especially on the straights. Fortunately they let us past eventually :)
Looked like rolling grid starts for a few laps there onto the straight, the two evo's would line up side by side and go for it, and Dave and I would do the same behind them
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
