  • Replies 112
my sunroof leaks.....
Wear a raincoat?
Well raining nice and heavy at the mo here( i am 15mins from lakeside) but i think it will clear.
It will still be a lot of fun come rain or shine.
A few of us northside boys will be heading directly to the track as we have a few things to finish up. what time should we be arriving at the track?
I think we have to be at the track by 4pm. ( going on what happened last time)
Trying to rig a camera in my car. if it works lok for the lovely white r33 with the pink camera on dash lol :rolleyes:
yeah we'll be there by then, just going to do pre track check on the cars now.
Happy laps is definately still on guys, have faith :nyaanyaa:
As somebody said, its looking better by the minute :thumbsup:
Yea mate 4pm we will be there
What a great arvo out, not even the slightly dodgy weather could of ruined that. hanks to the organizers and caterers and to the track staff for letting us have some fun and cut loose despite the moisture on the track.
Awesome arvo, damp track was a bit of fun in the GTR lol. Excellent to meet you rob, the 35 is absolutely mint.
My mates in the identical twin Evo's had a blast aswell.
And for those interested they have near exactly the same mods and on E85 punching out around 250-255kw. If you thought they were quick, thats why.
Thanks for making it a great success guys. Everybody behaved really well and had a tunnafun.
The next one is being scheduled for qld raceway at willowbank and will be a breakfast affair. Get outta bed you bums.
Cya there. :thumbsup:
Yeah was a great happy laps
mildly moist conditions FTW
MMmmmm I thought they were a bit quick, especially on the straights. Fortunately they let us past eventually :)
Looked like rolling grid starts for a few laps there onto the straight, the two evo's would line up side by side and go for it, and Dave and I would do the same behind them
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
