I believe the ecu itself has been flashed which is why I can have the safc on zero and still not ping.
Granted I'm only using the factory sensor but im not hearing or registering any knock on the safc either. The car ha knocked before with too much boost.
Sounds like it might be worth at least checking timing and making sure it wasnt advanced when it was tuned.
I might check the manual and see if there's anything I can check with the multimeter for the fuel pump.
I'm reluctant to take I to a local place as they have a tendency to charge for hours and hours and come back with nothing.
  • Replies 51
In that case find someone with a wideband gauge and at least use that yourself, better than nothing. You really shouldn't be tuning fuel without one!
Knock ears would be great as well but you aren't exactly going to go spend $1k on them for a back yard tune, maybe a visit to Melb is in order? Be cheaper than a replacement motor that is for sure!
Ok one more update.
I went for another drive, safc on zero, but this time I disconnected the exhaust gas sensor/O2 sensor. This is another test in the sevice manual for missing.
No missing at all with plug gaps on .8
I considered that because it is a cold night it was masking it so I sat in an industrial estate with my lights off and held 2500 rpm for period until water and oil temps were nice and warm and the bay was nice and soaked. It occasionally missed/popped during this high idle period but did not miss while driving or under load.
I'll test again during the day when it's warmer and might grab the sensor from my mates car.
The missing if caused by too rich will generally be worse in cold weather as more air, but heat makes the coils spark worse also.
Really think everything will be solved with a trip to a competent SAFC tuner who has tuned skylines before.
O2 feedback is only below ~3.5k on low load, if its missing above this it can't make any difference.
Also O2 feedback generally makes it leaner, if anything it should make the problem worse unplugging it.
Edited by Rolls
Interesting. Just to clarify, we're talking a ca18 here not an rb. I only mention this as you referred to skylines before.
See how it goes when the temp is higher. Cold dense air might have been masking it. Previously the critical miss point was 31-3200rpm
Update: Drove the car to work today as it's a nice sunny day, it's supposed to be 20 here today too so the drive home will be another good test. No missing at all with the Oxygen sensor disconnected.
Considering it's primarily track only I'm not in a hurry to replace the sensor. I'm going to put it on a dyno this weekend and check the AFRs after all my stuffing around and make sure it's safe before it hits the track again.
At the same time I could use the low throttle point map in the SAFC to take a bit of fuel out of at the cruising RPM with low throttle. Not as good as relying on the Oxygen sensor but better than nothing, that will only be if time permits as I'm not really concerned about highway economy. Let me know if I'm missing something else by not replacing it though.
So long as it drives well on WOT I'll be happy.
Side bar: Do the CA's have a diagnostic type port? I know they don't have a CONSULT port but do they have the standard 9 pin diag port? If so I can hook up a little diag box and check my timing easily too.
Dyno was a fizzle, the guy was a muppet. Went as he could fit me in this Sat, my n0rmal dyno guy was busy.
After dicking around for ages and continuing to tell me it was lean all the time, I added full correction for fuel on the SAFC (50%) the car is missing, popping flames, big plumes of black smoke from the unburnt fuel and he goes still lean. turns out his sensor is f**ked.
Not only that but he wants to run it by sitting at 60km/h in 3rd, no load no boost, then continuing to add load on the dyno and adding throttle so it just holds at 60km/h so essentially we're driving up the steepest hill in the world at 60km/h in third. The car just loves that.
He spent more time talking about his divorce, pending lawsuit with the epa, and on the phone to the guy from Mainline trying to work out how to give me the damn graph i needed to see (he could only give me real time data and nothing recorded over a run) than he did anything else.
In the end, he cracked it, I cracked it and we went our separate ways (I didn't pay anything). I'll go to my normal dyno guy next Saturday.
Good news is that other than when it had stupid fuel in it, it didn't miss on the drive over or back or on the dyno. Must have been the O2.
Sorry if this has been posted already. Whats your fuel pressure?
Not having a dig at all, but these sorts of threads pop up fairly often and there's never any basic diagnosis done. Just alot of parts thrown at the car in the hope something will fix it.
Hope you get it all fixed soon :)
  • 3 weeks later...
An update to this.
I've since bought and fitted and AEM wideband so now I can just road tune the car myself, unsurprisingly it's a little rich down low and by a little, i mean a heap - richer than 10:1 - and
then it's a touch lean up top nipping at 13:1 so I'll bring that back to around 12.5 and dial out some fuel down low.
Should be apples :)
EDIT: Forgot I'd already been a good boy and updated about the O2, woops.
Edited by ActionDan
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
