  • Replies 52
Can't wait to try it can't justify spending 100 bucks on oil for big name stuff
most oil changes are $100+,
if you want Power then thats the Price you will have too pay,:thumbsup:
I strongly doubt that a change in oil to a different brand of fully syntheticc oil will result in a rebuild :whistling:
No but running a cheap oil thats not right for the job in `st place is Paul weather here & run 5w30 pinch.gif
Its only cheap because its on special, United 1 5w50 in normally over $70 per 5ltr pack. Its a full PAO and Ester synthetic, not a hydrocrack mineral oil
United Oil is not a small back yard company, they are Quality assured and API licensed and bigger than most of the brand names you know of in Australia. Also have a complete range of double ester engine and gear oils.
Guys, dont get caught up in brand name hype!
Ash
Ash
exactly what i was getting at ash no point following big brand hype if it going to do the same job
  • 2 months later...
Bringing up a old thread changed to the united 1 oil 5w50 from ash. It's fully synth and so far it has been great I now have good oil pressure on cold starts (70psi approx) and on idle it now is about 40psi instead of 25. So far I highly rate this oil and for half the price of royal purple etc I don't think I'll ever look back. If ash is still doing a bulk deal I will buying in bulk in the very near future.
Once again thanks ash
Does United Oil make any 10w40, if not would it make much difference running 5w50 vs 10w40 ?
I guess that 6x5L for $200 deal is long gone >_<
I think i's a 5W50 and 10W60.
PM Ash he'll tell you if it's still available. I have a few 5L bottles from my buy if the deal isn't still on :thumbsup:
Yes the 5w50 is fine and so is the 10w60
The reason I went for the 5w50 was price and the fact that it doesn't get track work. However 5w50 is fine for track also. Go to www.unitedoil.net.au and use the contact us form and ash will reply
  • 1 year later...
Glad your happy luvpsi
Sorry for the late reply, I have been offline for about a year.
We only have Ultimax 10w60 and United1 5w50 in full PAO/Ester synthetics available in Australia. We do make a wide range internationally but we only bring in these 2.
Also have the United 171 Double Ester 5w40
I do have group 3 Hydrocracked synthetics in 0w20, 5w30, 5w40 and 10w40
I can still offer the old special at $200 for 6 x 5ltr United 1 5w50 PAO/Ester
Ash
    • Only if you do not You will not be able to drive it with any serious load without risk of it pinging, which will either slowly or rapidly kill it, depending on how bad it is.
    • Hi guys, I’m new to the GTR scene. Picked up an R33 GTR earlier this year that needs a lot of love. I’ve been going through the hot side, changing all the gaskets and while it was all off I managed to score a set of -9s. It still had the stock ceramics so I was pretty happy to get the 2860s.  I live in a small country in the pacific with 0 performance car scene. No dyno’s no performance parts, let alone stock parts for a skyline. I order everything from Australia and do it myself. This means I’ll be running the stock ECU. Maybe down the track I’ll get an aftermarket set up and do a remote tune.  Will the car run -9s on stock tune safely?  I have a very heavy foot so I really hope so 😂   thanks guys
    • perfect, no rush to address the leaking bush then, it's not doing much/anything
    • I'm not sure if it will bolt up, but.... I'm reasonably sure that the ID of the runners is somewhat smaller on the NAs. So it probably wouldn't be a good match at the flange where the top and bottom meet. So that would be a reason to not do it. And the skinny runners would be the bit you're keeping, which would be a reason to no do it. You'd want the big runners if you were doing any work to swap stuff. Why not just use what you've got, like nearly everyone else who has +T'd an NA? You don't need or want the TCS throttle or other stuff that is specifically DET inlet/crossover.
    • lol already been put in temporarily 3 years ago
