Hi guys
I've been looking at sway bars for my gt8 on ebay.com and found that there are a few v35 sway bars (namely Godspeed)that fits only coupes
Is that entirely true or does it only NOT fit there AWD version of G35 there? ... what I mean is, does the coupe sway bars fit the sedans as long as they are not the AWD version?
Does the whiteline in the group buy here fit both?
Anybody here can shed some light on this?
cheers!
https://www.sau.com.au/forums/topic/372281-sway-bars-for-v35-sedan-and-coupe/
  • 4 weeks later...
Hi guys
cheers!
Mate, it's been a while since I've been to the forum...Do a search on my posts...I did do my sway bars for my GT-8, a very noticeable difference...the brand was stillen from the USA...and by the way, I drive a MY11 WRX now...sorry to say this, but a better car overall...
Thanks mate; ended up hooking him up through one of my Whiteline Group Buys.
Cheers, Dale.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
