Hi guys/girls,
Unfortunately I no longer have my r32, therefore all the parts i've hoarded over the years must go.
All parts work perfectly, any inspection welcome only if your serious, please no time wasters.
Used:
R32/s13 rear camber arms upper and lower (missing adjustment pins) $60
R33 front pair LCA's $180
r32 rear passenger LCA $60
Standard r32 gtst cat back exhaust with cat $100
Standard r32 gtst intake box with snorkel and intake pipe $100
Standard r32 gtst side mount intercooler only with some piping $30
Standard r32 headlights $180 pair
Standard r32 passenger indicator $40
standard r33 (s1 i believe) turbo, tight shaft with elbow $180
R32 REO bar $80
r32 gtst Complete air con assy $80
s13 boss kit, was on car for under a week $20
Jasma exhuast $50
R32 gtst Stockies 2 with road worth tyres 2 without $140
RAY's Wheels C-Ultras 2 x 17 x 8.5 +34 & 2 x 17 x 9.5 + 38 $350 or $400 with spacers
off r32 gtst one wheel has buckle (~$50 to fix) but does not leak any air, great for drifting, they are really light, wont find any rims this light for this price.
Spacers are required to clear brake calipers. will need rubber for all 4.
2 x 25mm spacers 2 x 10mm spacers
Brand NEW BITS:
Kazama caster rods to suit r32's etc..... $260 I bought it for $300 never been used
Bosch 040 fuel pump still in sealed plastic $170 I paid 200
Uras Handbrake shoes, never been used $220 i paid 250
Apexi AVC-r boost controller in limited edition black never been used $550 i paid $660.
PARTS FREE to a good home:
standard r32 spoiler black
coil pack looms ( have like one clip missing, the other has like 2 missing, can do bodgy cut and shut job).
standard r32 gtst steering wheel, leather is ripped.
r32 4pot brake pads have a bit of meat left
standard r32 brake lines, one of the front ones has rubber split but does not leak, would advise not use this one, but others are fine.
standard r32 front chrome garnish? the bit that sits under the hood ontop of the front bar
air ducts for standard r32 front bar (not sure which side)
various plastics, front wheel arches, some rear and boot surrounds
Blitz nur spec r silencer (the bit that bots into the cannon)
Standard front r32 electric spoiler...
I think thats it for now, I think the prices are fair, if you think otherwise let me know, and why.
preferred if you got me on my mobile, Message anytime, or call when you think id be awake <removed>, Issa.
Thanks
Update CLICK to see pictures.
https://www.sau.com.au/forums/topic/372513-new-and-used-parts-freebies/
How's the suspension like? Hard? Soft? Comfortable? Ive got an R33 so I might be interested if you will separate the fronts from the rears.
The nismo coilovers ride like standard, they just feel better. IMO best for the street.
EDIT: ATM dont want to separate.
What the size of the exhaust silencer?
have someone picking up the silencer tonight, ill let you know if they dont get it.
Edited by phat_man
