Hi guys/girls,
Unfortunately I no longer have my r32, therefore all the parts i've hoarded over the years must go.
All parts work perfectly, any inspection welcome only if your serious, please no time wasters.
Used:
R32/s13 rear camber arms upper and lower (missing adjustment pins) $60
R33 front pair LCA's $180
r32 rear passenger LCA $60
Standard r32 gtst cat back exhaust with cat $100
Standard r32 gtst intake box with snorkel and intake pipe $100
Standard r32 gtst side mount intercooler only with some piping $30
Standard r32 headlights $180 pair
Standard r32 passenger indicator $40
standard r33 (s1 i believe) turbo, tight shaft with elbow $180
R32 REO bar $80
r32 gtst Complete air con assy $80
s13 boss kit, was on car for under a week $20
Jasma exhuast $50
R32 gtst Stockies 2 with road worth tyres 2 without $140
RAY's Wheels C-Ultras 2 x 17 x 8.5 +34 & 2 x 17 x 9.5 + 38 $350 or $400 with spacers
off r32 gtst one wheel has buckle (~$50 to fix) but does not leak any air, great for drifting, they are really light, wont find any rims this light for this price.
Spacers are required to clear brake calipers. will need rubber for all 4.
2 x 25mm spacers 2 x 10mm spacers
Brand NEW BITS:
Kazama caster rods to suit r32's etc..... $260 I bought it for $300 never been used
Bosch 040 fuel pump still in sealed plastic $170 I paid 200
Uras Handbrake shoes, never been used $220 i paid 250
Apexi AVC-r boost controller in limited edition black never been used $550 i paid $660.
PARTS FREE to a good home:
standard r32 spoiler black
coil pack looms ( have like one clip missing, the other has like 2 missing, can do bodgy cut and shut job).
standard r32 gtst steering wheel, leather is ripped.
r32 4pot brake pads have a bit of meat left
standard r32 brake lines, one of the front ones has rubber split but does not leak, would advise not use this one, but others are fine.
standard r32 front chrome garnish? the bit that sits under the hood ontop of the front bar
air ducts for standard r32 front bar (not sure which side)
various plastics, front wheel arches, some rear and boot surrounds
Blitz nur spec r silencer (the bit that bots into the cannon)
Standard front r32 electric spoiler...
I think thats it for now, I think the prices are fair, if you think otherwise let me know, and why.
preferred if you got me on my mobile, Message anytime, or call when you think id be awake <removed>, Issa.
Thanks
Update CLICK to see pictures.
https://www.sau.com.au/forums/topic/372513-new-and-used-parts-freebies/
How's the suspension like? Hard? Soft? Comfortable? Ive got an R33 so I might be interested if you will separate the fronts from the rears.
The nismo coilovers ride like standard, they just feel better. IMO best for the street.
EDIT: ATM dont want to separate.
What the size of the exhaust silencer?
have someone picking up the silencer tonight, ill let you know if they dont get it.
Edited by phat_man
    • Lets say I wanted to buy this, specifically for this purpose. How do I actually perform the function. Can I still buy a Consult-1? Am I about to be burned by the fact my car is a 2000 model Series 2 R34 and thus will be some stupid other system? Do I just need this -> https://obd2australia.com.au/product/nissan-consult-14-pin-to-usb-ddl-diagnostic-interface-with-ftdi-ft232r-chip/ And with what software?
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
