Hey guys,
Having a clean up sale, found some items whilst moving out, and some came off the new car.
1. Momo Race 350mm steering wheel
a little worn
$100 posted
2. Topstage S14.5 Guards
Brand new, no longer going ahead with conversion
$250 posted
3. Universal rails
Brand new, make your own custom rails
$40 each posted or $70 pair posted
4. Greddy catch can
New car has catch can, so no need
$80 posted
5. Nissan Skyline/Stagea intake kit
Has no BOV inlet
$120 posted
6. Universal side mount seat rails
No need for them
$30 pair, or $50 for all posted
7. Oil cooler with with oil filter relocation
New car has a kit, no need. Has a few rub marks still holds pressure. Unsure of brand.
$250 posted
8. H4 HID kit
Hi/lo beams brand new
$80 posted
9. Tanabe undercarriage brace
Stiffen up that Stagea
$200 shipped
10. Stagea rear cradle package
Reduce the rear track on your Stagea with the following
S14 turbo rear subframe
R33 5 bolt half shafts
$200 or $250 shipped
11. Nissan Stagea NA Grille
$100 or $120 posted
12. Also got my worksbell boss kit for C34 Stagea for sale. Includes horn wiring and airbag light bypass, simply install with no fuss.
$100 shipped.
Located in Liverpool region
PM me or text on 0410-65-1989
Adam.
Edited by Run-It-Hard
https://www.sau.com.au/forums/topic/372933-run-it-hard-garage-sale/
item 10 revised.
10. S14 turbo rear subframe
Great for reducing rear track in Automatic Stageas, eliminating HICAS in Skylines etc
$ 80 or $120 shipped
They won't bolt up to anything without Malone brackets.
READ BELOW!
Please read this whole thread before PMing me, I am getting sick of PM's for things that were sold a month ago, I have stated in the thread what is sold. I will not reply to PM's for items have been already sold.
Thanks.
READ BELOW!
Thanks.
So does that mean item #3 is sold. I didnt see it marked as such. If not, i'd be interested in them.
Thanx,
Ian
Nahs those aren't sold Ian, I've just been getting PM's the past week for things that are sold and it's driving me mad!
You'll need to make mounts for the seats and to bolt into the car for them though, a bit of work.
Ok, no sweat. You still at the same address or have you moved?
Let me know on 0423 204 997.
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
    • Assuming your brake pads are not worn right down, I'd add a little brake fluid. Is there any sign of a brake fluid leak?
    • Hello all,  I need of some help. On my drive home my handbrake light lit up and started flashing. When I got home I checked my handbrake sensor under the centre console and nothing seemed out of the ordinary. I have scanned my car via the consult port, no codes shown. Checked my brake fluid as well which is half full. Tried unplugging the brake master but it didn't change anything. Thoughts on what it could be? The master float doesn't seem to be stuck. My car is an 1998 ER34 sedan GT. No hicas but has ABS Photos below 👇🏾
