Hey guys.
Stripping my 97 series 2 r33.
all exterior parts
headlights R/L (with Hid 6k) - $200 each
Doors R/L come with windows - $200 each
all interior parts
front seats - $150
rear seats - $100 (has 2 ciggie burns)
seat belts - $100 for front and back
carpet - $50
glove box - $30
centre console - $50
dash board - $150 (105XXX)
Gear knob - $30
______________________________________________________________________________
Engine/axel/control arms/diff/disc breaks/ the whole remaining car |
Engines and the rest of the car are in good condition, no damages. |
Everything you see in the engine picture is what you get + the whole car, the wheels on it etc |
$1200 guys |
______________________________________________________________________________ |
https://www.sau.com.au/forums/topic/373135-1997-r33-gts/
  • 3 weeks later...
  • 3 weeks later...
Engine/axel/control arms/diff/disc breaks/ the whole remaining car (R+L front fenders)
Engines(105XXXKM) no damages.
GEARBOX
Handbreak
WHOLE REMAINING CAR
$800 MASSIVE PRICE DROP!!!
Your going to need to bring springs or coils to get the car moving though.
https://www.sau.com.au/forums/topic/373135-1997-r33-gts/#findComment-6009133
  • 2 months later...
hey guys
Parts still for sale
front seats - $100 each.
rear seats - 50(need a clean)
glove box - $30
Price not negotiable
https://www.sau.com.au/forums/topic/373135-1997-r33-gts/#findComment-6143424
  • 2 months later...
  • 4 weeks later...
