wrecking Nissan skyline r33 gtst 1996
lots of parts available just ask cheers
motor rb25 det series 1 bare motor $1000
gearbox $1300
pedal kit $200
tail shaft $200
flywheel $80
diff lsd $300
cv joints $60 each
stock springs & shocks $250
cannon with hi flow cat back system $400
brake master cylinder $80
front calipers $250
front disks $70
rear calipers $150
front hubs $100
rear hubs complete $250 no calipers
upper control arms each $30
lower control arms each $70
cross member $100
rear upper control arms each $25
rear lower control arms each $75
power steering rack $100
p/s bottle $20
Hicas $80
heater core $100
stock computer $150 (man)
speedometer $120
taillights $100 each
skyline tail light piece $100
power window reg $120 each
ignition barrel plus door locks $150
blinkers switch on dash $50
ac display $70
rear bar $200
rear bar reinforcement $100
boot $170
boot shocks $50
doors $150 each
rear cut $600
beaver panel $100
fuel flap $10
fuel cap $10
carpet $70
battery holder $20
washer bottle $20
radiator overflow $20
glass from $50
fuel tank $30
fuel pump $80
fuel lines $100
door trims $80 each (bare)
boot trims $90
interior light $20
seat belts (all 5 ) $150
dash $80
dash vent and surround $80
antenna $50
call me on 0426504272 car is in Liverpool area
can post anything you want as well
  • 3 months later...
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
