I have a set of R34 sedan sideskirts in Sydney.
I'm not in Sydney, however I bought these over the internet on eBay and had a friend of mine in Sydney pick them up. In-between getting organising shipping, I managed to pick up another set locally. So - these are now useless to me.
Based on the pictures I've seen, they seem to be in reasonable condition. The seller didn't indicate whether they were real or fibreglass, so I don't know. They're silver in color (I believe KV2), but they will likely need a respray.
I'm looking for around $150 - what I paid for them - but I'm open to offers.
https://www.sau.com.au/forums/topic/373325-r34-sedan-sideskirts/
able to ship to qld?
I guess I can ask my friend in Sydney whether he's able to bubble-wrap them up and get an idea on postage, but I don't imagine it would be cheap.
Easiest would definitely be a buyer in Sydney able to pick it up, I think. I can't easily organise anything from SA.
  • 4 weeks later...
He thinks they're probably fibreglass, but he can't be sure. The dramas of the skirts being in Sydney!
You're welcome to have a look or email / phone him - his email is [email protected] & mobile contact is 0415123004
  • 1 month later...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
