hey guys just wondering. ive seen 2 r34 GTRs and theyve both had the 100,000km sticker on the airbox but there 60-70k on the dash. the car looks to be in mint condition and genuinly 60k kms.. the sticker has asain writing aswell but i cant read it.
anyone know what this means?
cheers
https://www.sau.com.au/forums/topic/373666-100000km-sticker-on-airbox/
I have a similar sticker its a service sticker from nissan Japan on my V35, it shows KM and a month so i have no idea what year it was put on, the car was ether exported just after a service or it was wound back around 50k
I think it means the 100k service was done, specifically the timing belt as gtr owners are fussy and know that rubber corrodes after a few years.
Mine has a genuine 31k now but im doing my timing belt in about a month as its almost 10years old now and would prefer that piece of mind.
Yeh i dont have one of them due to the chain not belt in my V but that sticker is like the skyline owners worst nightmare to see that when the car was imported with less KM then the sticker says
Edited by T4NK
It's amazingly common mate. Don't stress about it, none, well, VERY few come in with genuine kays. Always base the purchase of any import purely upon condition.
    • Was that with the cas upside or correct way up?
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
