SOLD my R32 and got a few parts which i didnt get a chance to install before i sold it ..
- (BRAND NEW) R32 JJR split dump/front pipe including gasket still in bubble wrap $200 ($269 at JustJap)
- (BRAND NEW) R32 leather gear and hand brake boot cover $35
-(BRAND NEW) S15 Perfect fit fibreglass subwoofer box / can also be use in other car make =]] $80 ( got it for $100)
- (USED) CIVIC EK 98 headlights in good condition $50
i forgot how to upload pics so if you need them give me your email or phone number and i'll send them to ya
any question give me a call..
David - 0421 151 651
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
