Hey guys i've got up for sale a set of Axis Hiros.
I got these from the US a couple of monthes ago and paid close to $2400 shipped but never really got to roll around with them.
I Put them on my car for maybe 3 days max and drove with them for a max of 50km.
They are 19x8. Forgot the offset but it fit my JZX100 real nicely.
They have been resprayed to Satin black looks real nice on a white car and i don't think there is a hiro set out there in satin.
Now im not going to BS, the tyres that came with it from the US were absolutely shit and had cracks in it which reached the radial so im going to take them off coz i don't want people to be feeling like they're getting ripped off so the price is for rims only.
Im asking for 1K ono. Has blemishes here and there from being stored away and my mum dropping stuff on it, but its not very noticable especially coz its satin. So practically a brand new set of rims in Satin for 1K!!!
Located in S.E suburb of Melbourne. Pm me or txt me on 0406978622 cheers :)
Edited by RxGTR
https://www.sau.com.au/forums/topic/374201-19-axis-hiros/
hahaha to be honest i hate having rims that look the same as everyone else's which is why i did it. i put them on my friends silver 100 as well and the satin just makes it look completely different to the normal gloss black wheels out there coz the sun hits it differently. has a slight sparkle to it too :)
honestly i don'ttt remember the offset i think its around +35ish. and the tyres were BCT. Cheap chinese ones. Shattered that they arrived and had huge gash looking marks but i guess for how cheap they are the rubber dried up and just cracked on the trip here =[
https://www.sau.com.au/forums/topic/374201-19-axis-hiros/#findComment-5968645
  • 3 weeks later...
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
