cut a long story short, basically my car has a 2.5" exhaust. I plan to get a full 3" set up (I'll grab a dump pipe and hi flow cat from BATMBL) so I'm after a cat back system.
I got quoted $650 for an XForce cat back with a 6" cannon with 4" tip (which is what I want). This sounds kinda cheap. I got quote a similar system from Hitech mufflers for around $1100...
Can you guys make any suggestions?
https://www.sau.com.au/forums/topic/37456-i-need-a-new-exhaust/
I'm in a similar situation, but I was thinking of going for a Trust Power Extreme II.
Suggestions?
I've got the 180SX version of the PEII with a high-flow cat and bigger front pipe. It gave a good torquey increase in mid to high-range revs (doesn't feel choked at high revs anymore) and it's nice and quiet around town.
Still plenty loud when you open it up though. ;)
Bakadesu - I have a 180 with stock exhaust+pod at the moment, and oh yeah! I so know that feeling of 2500-3500rpm surge in power but after that its just flat ;) I'm looking around for a 3" turbo back with high flow cat, cannon muffler. I'm thinking of getting the PEII from Japan, but the shipping is 50% of the actual price almost. :(
full 3" exhaust system in melb for about $950
from turbo back, mandrel bent, mild steel. no brand. ive been recommened to get no brand ones as they are generally better quality than the hks / trust ones for $1400 - better grade steel. so i was told anyway
they r not necessarily better however they r just as good in my opinion.
most hks or trust kits sold are usually just a cat-back system
but comparing 950 to 1400 id go for the no brand for sure
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
    • wedding eh.....I seem to get to more funerals than weddings or christenings these days....
