Condition as per item description:
Uniden CB radios, uh038sx-2 with charger base.
Good condition.
$50 SOLD
D1 spec coolant breather tank, brand new.
$20 SOLD
GFB blow off valve. Good condition.
$20 SOLD
Fusion sub and box, sub is new box is used.
$50
Amp 2 channel, good condition, few scratches.
$40
Both sub and amp for $70
Items in Western Sydney NSW.
Pickup for larger items.
Postage of items: registered post. No responsibility will be taken for loss of items once posted. It's up to the buyer to sort out insurance ect.
Interested in CB's; can you PM me some details (range, battery life)?
Happy to come & pick up.
Cheers, Dale.
Edited by Daleo
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
