Selling my track car as need cash for renovations
1990 track only gtr big hks single turbo setup
Hks manifold
Hks waste gate
Big hks/garrett turbo
Large fuel rail
1000cc injectors
Power fc dejetro
Hasnt been tuned for injectors yet
Serge tank and external pump
Stripped interior
Trust intercooler and piping
Fibaglass front bar
Fibaglass front gaurds
Fibaglass boot with n1 lip
Brand new comp stage 5 clutch
Needs finishing but will be a fast car
Internals unknown asume stock
Heaps of spares
Contact 0411672105
Located central coast nsw
$12500
SWAP FOR CHEAPER TRACK CAR AND CASH
https://www.sau.com.au/forums/topic/374941-r32-gtr-hks-single-turbo-setup/
  • 1 month later...
Track only inport...
New yellowjack coil packs and spark plugs starts and runs but rich as. touch up tune and will make 320-350 wkws
Make some offers trade ins welcome
Is this over priced or do I just need to wait for some interest
im not expert but maybe for a non register-able track only gtr.. im looking for a track only gtr but not willing to spend that much. i have seen a few on here (already sold) for around the 7k mark which might be more like it.
http://www.skylinesaustralia.com/forums/topic/358302-r32-gtr-track-car-7000/
That's a good price for a base unit has 1500 in ecu and over 2k on the hot side let alone and also fuel system over 1k clutch band new over 600 that's y I think its worth 10k. It owes more and only had for 6 months and never even drove It
i remember this on ebay from the fiberglass front and the turbo setup, it had 2 sets of wheels on it and said it needed a tune in the post, i remember the price it was listed at but there is no point writing that up, when you picked it up was it running rough?
if so what was the problem?
what things have you done to it since purchase?
and what sort of compression does the motor have?
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
