Hey guys, i started up my car yesterday from cold and while working under the bonnet, noticed a coolant trail coming from under my car. i put the car up on a hoist at work and found that it was coming from the back of the block. i cant pinpoint the leak 100% because i cant see whats behind there from the top of the car or the bottom. i cant even reach my hand behind there. Theres just F-all space! I managed to squeeze a mirror behind there and saw a small section of hose maybe 10cm long or less. I reckon its coming from there. Can anyone confirm this? Or better still does anyone have a pic of the back of the engine just so i know what im dealing with? Any help appreciated.
cheers, Steve
https://www.sau.com.au/forums/topic/375192-rb20-coolant-leak/
yeh there is 2 hoses that run around the back of the engine that carry coolant as well as the larger heater hoses.
The smaller hoses i genuinely couldn't see how to change them without taking the plenum off. I decided to change all of the coolant hoses which pretty much requires you to take the plnum off anyway.
cheers, Steve
Hey Steve,
If you have small hands(and dont mind carving your knuckles up a bit(adds to your character)) you can get in there lol, and yes there are two small hoses back there (bout 15mm diameter from memory) one is bout 10cm or less in length but cant remember the second one sorry. Definitely change both these hoses.
There is also a bent shaped hose under the plenum(bout 30cm long with a chicane type of bend in it), it runs front to back along the block just under the plenum might be worthwhile changing that too while your at it.
hope this helps
Mick
there is about 9 hoses if you want to replace all of them that run around and under the plenum, including radiator hoses and those 2 that run around the back
you really need to get them from nissan because they are moulded and you pretty much can't just get a straight peice to do the job
they aren't cheap but totally worth the peice of mind
there is a spring like device (dunno what its called) that you can put over straight hoses that enable you bend the hose without it kinking, that may be an option if the nissan parts guy tells you the hose(s) your after have to come from japan and you haveto wait weeks to arrive
no i did those hoses a couple of years ago now, i went into nissan and stood there with them on the program and pointed them out when i ordered
steven that's ok for a single bend, and only to a certain degree
a lot of the hoses have multiple bends etc
it could work for the mean time on the hose he's talking about as it's only a single bend and not too tight
but it's almost impossible to get at the hoses down the back there without taking the intake off, which you're better off waiting until you have all the hoses
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
