Hi all am about to own my first skyline, a 32 Gtst.
Have just come from a 12 sec 200+kw atw manual legnum and hope I can replicate those kind of figures with the 32 fairly comfortably to :)
Looking forward meeting folk on here and doing it all over again with s skyline!
https://www.sau.com.au/forums/topic/375264-new-kid-from-sydney/
Haha I'm a mechanic so plugs aren't too bad on the legnum...just like a magna really...,I'm more excited about having a nice simple rwd setup!
You think a 25 is the go hey? Not disagreeing but I might stay true to the ol' 20 and build it up...then again might go '25. I'm not looking for monster power low 200's atw is plenty for me :) if money permits though might go 25 :
Thanks for the welcome!
Edited by the_wolf
I would stay with the rb20. They are a tough lil engine and if worked on properly you will easily be able to produce that power figure. My r32 gtst i just sold had a high flowed rb25 turbo, exhaust, front mount cooler, fuel pump, injectors and a tune and made low 200's easily. Was a fun little car. Best of Luck and welcome!!!
+1 for the rb25 conversion. sure you can get power out of the rb20 but at the expense of low end power. you can get the rb25 to be knocking on the door of 200kw with stock everything but exhaust and cooler (with the boost bumped up a bit) and it will be making full boost by around 2700rpm. even with a turbo, ecu and injector upgrade you can make around 250kw and still have full boost by under 3000rpm. to get even 200kw from the rb20 you won't be making full boost until closer to 4000rpm.
^this is true but the 20 is a solid unit and is more than happy to rev its head off all day. I had a 20 with a to4e + supporting hardware with 210rwkw, was a ball in a nice light chassis. The 25 does have more scope though, by the time youve done up a 25 you could have a 26 with light mods.
Yep can totally understand the benefits of a 25 in terms of low end torque....it simply comes with the capacity. At the moment though as I e cone from an awd turbo background im going to be getting the suspension and brakes exactly how I want them and learn how the car behaves before chasing more power.
you can get that sort of power out of the stock turbo on a 25 with just an ecu (and a shortened turbo life). if you are willing to run the gauntlet you can get up to around 220kw on the stock turbo at about 16 or 17psi through the stock turbo.
Yeh I'm happy with 240-250, that's plenty for me...but I want it to be useable power, I don't know whether the 20 will have as much of a street friendly useable 250kw as a 25 would
No way in hell!
Get ready for the torqueless goatf**ker compared :P
Lmao yep I sort of figured....oh well might drop in a 25 down the track when funds allow...
To save all the to and fro with questions I have about how easy it is to swap to a 25...could someone post a link to some info? Thanks
search function is sometimes a bleeep
i usually type the question (if its pretty normal) into google and it comes up with the relevant thread on sau
http://www.skylinesaustralia.com/forums/topic/119865-rb25-into-r32-basic-guide/
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
