Hi all,
Got up for grabs a turbine that I have only had for around 3 months.
Item is a Turbonetics T66 850hp rated turbine.
Compressor uses a 4 inch intake with 2.5 inch outlet. From the spec I was able to dig up up its around the 0.9 exhaust A/R size. 3 inch V Band dump flange
This item is currently still fitted to my car, its been tuned on a internally standard RB26 and suprisingly isn't to laggy. Its set at 14psi and makes full boost by 4400rpm and is running around 300rwkw with this boost setting.
Plenty of power left in this unit, I am looking to move this on as I have finally figured out what spec and turbo combination I want to run with my car and this item will not meet my requirements.
My best contact is 0419 670 966.
I am unable to attach pics so if your from out of town and are interested please send me a pm with your email address and i can forward some shots of the turbine to you.
NOTE: This is Turbine only. No exhaust manifold or wastegate. The turbine can be supplied with the oil line kit if needed however will only suit RB26.
Price is $1250 Freight Included.
Turbine will be removed once inspected and price is agreed upon and paid for in full.
Cheers Marty
https://www.sau.com.au/forums/topic/375545-turbonetics-t66/
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
