hey guys i just seeing how many ppl would like to buy my V4 nistune ecu im after $650 ( as i think the ecu is worth about 100?) thats for the board and ecu its running stock map un changed or tuned ill take less if you swap me your std ecu as i need to drive the car to the work shop and the new 1 needs a std ecu case its installed in my car atm so can see it running .. it was sent to confidyne and they sent it with there one 2nistune
im getting a vipec v44 to replace it im over the afm i want to piss it all off and get a nice big intake and custom air box setup
( note not 4sale as yet just looking to see if any1 would buy it )
https://www.sau.com.au/forums/topic/375797-eoi-r34-nistune-4sale/
  • 4 weeks later...
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
