Some have reported good results some havn't.
:D
I've decided to do the mod again since I am running a bit more boost up in the higher rpm's due to my bodgy wastegate mod that reduces the wastegate travel. I'll let you all know if it makes boost in the higher rpms as previously the way the wastegate was setup it would hold boost perfectly.
Theoretically it should creep boost the higher the rpm's go IF the re-circ leak was causing some boost drop. This is only the case with the way I have setup my wastegate hence reduced travel so boost is forced to be made.
I recessed the hole a little so the top of the screw would sit flat. As not to accidentally lift the bov on one side hence leaking out the side of the gasket.
The screw I used was a good ol' short stubby computer case fan screw.
While I was there I checked the piping to see how coated with oil it was.
Suprisingly after 160,000km's (90,000km's of hard 1bar+ boosting, currently 1.1bar 16-17psi) its all pretty clean. Slight bit of oil on the bov its self however the piping is rahter clean. Well compared to 95% of the other R32's I have seen.
https://www.sau.com.au/forums/topic/37606-stock-bov-leak-fix-mod-pics/
I have noticed the following since the mod:
1. Boost is definately much much quieter. Similiar to a car that has a stock airbox.
2. Appears to feel like it has a little more guts down low.
3. Boost appears to be a little lethargic when first starting to make boost - this could be due to not hearing the psssssshhhh as boost comes up.
4. This mod only appears to be of benifit when running 15+ psi.
5. Boost does creep up like I thought.
6. Constantly hits boost cut now :) Time to fiddle again.
7. Changing from first to second when accelerating moderately some times is a little rough.
Think thats it.....
How are the aftermarket re-circ bov's setup? Do they have this recirc bleed type hole?
I don't think they have Joel, well the TurboSmart one that a mate has got hasn't.
I've always wondered if a aftermarket plumb back would give the same feeling as this BOV mod does....
J
It definately does hold boost easier up top now.
I've had to back the boost off so it doesn't boost cut.
I didn't notice any difference at the lower boost levels though (13psi @7000rpm) as it would hold 13psi at 7000rpm easily anyway.
The problem began when I started to try and hold 1bar+ up to 7000rpm.
As I said previously I elongated the wastegate holes in order to reduce the travel of the wastegate hence forcing it to hold boost. So obviously there is a little to be had by stopping the constant re-circ with the stock bov.
Yer the RB20t wastegate is a tougher wastegate (stronger spring).
When I had the VG30BB wastegate on it she would drop boost to around 9-10psi like yours.
The RB20T stocker wastegate with exhaust is 10.9psi. Well mine is anyway. :)
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
