I am not a trader i just have a friend that is an importer and a sale did not go through so i am posting on here for him, it is basically his car. 539Hp Dyno sheets included.
Here are the details below , i also have plenty pics msg me for 15mb worth of photos . Underbody photos , interior photos engine bay photos even photos of the engine being built.
13,000kms on the Nismo 320km dash cluster but its real kms are about 60-70,000kms I can tell you that for sure, Its built by a very well known tuner in japan that has built 1000+hp Gtr’s which have been in magazines a few times. It has only done 300km on the new rebuilt engine.
More in detail below:
Nissan Skyline GTR R34 Vspec I
H11(1999)
White
No accident repairs
550ps-600ps
**Engine system**
Full overhaul
Bored out to 2.7lt
87Ω BNR34 standard piston
TOMEI strong conrod bolt
TOMEI strong head bolt washer
TOMEI metal head gasket
BNR34N1 oil pump
BNR34N1 conrod metal
TOMEI 264 9.8mm camshaft
All consumables have been replaced
**Cooling system**
GARAGE ITOH original side flow radiator
TRUST oil cooler
HKS intercooler
HKS special piping
**Fuel system**
TOMEI strong fuel pump
700cc injector
**suspension system**
BRITZ suspension
ENDLESS 6 pods brake calliper kit
**Other**
HKS Fcon Vpro computer
HKS GT-SS Turbo
Full titanium muffler
NISMO twin plate clutch
Contact me ASAP for this amazing offer. Andrew- 0420496076
Edited by GTRAAH
I disagree.
To quote your thread in the Importing section:
I can import any vehicle from japan very good prices, Example I have a 540Hp R34 GTR Vspec Available for $55,000 on the road. Another example R35 GTR = $110,000 on the road.
My name Andrew - 0420 496 076
Just call me or pm me with car details and i can source for you and get a price.
Cheers
Get your story straight, and read the rules of the forum before you post again.
Admin
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
