Stevesn just upset cos u r whoring his thread, but we all know he whores everyone elses...
nah, just trying to redirect Matt away from this whole drag thing, and it worked:p
The signal guys will be here for a few days at least. James has a lot of spares there, so most things shouldnt be a problem - its amazing what you can source on short notice if you have to. Signal can make things happen pretty quick too, James got some tyre sent out from Japan within days for the Melb drift comp because signal made a phone call for him. they have alot of sway with other companies in Japan, PLUS they have a huge number of bits on the shelves over there - so when the manager of Signal calls and tells them to make something happen, it will. (Hiko san, the manager of Signal will be out too, he is the owners brother, so if he cant make things happen, they were never meant to be)
Fuel, well thats easy, just drain and refill.
If everything goes pie eyed, well thats just the nature of the beast - it does happen. But this sort of opportunity wont come knocking too often. If I worry too much about what might go wrong, then I would probably never get anything done. Spose all I can do is prep the car the best I can, plugs, fuel filter, make sure there isnt anything else obviously wrong and leave the rest to the gods:)
  • Replies 114
  • 4 weeks later...
AFAIK its still going ahead - have to check. James was trying to get it orgainised for mid May to coincide with the Drift day - he mentioned Bai was planning on heading over at the same time so he could carve up Mallala.
I will have to confirm dates, unless autObarn is out there and can confirm?
Hi all
seeking expressions of interest
D1 Garage are looking like getting Signal Japan's top tuner out here to perform their magic, they will be bringing all the laptop software for Japanese ECUS.
It wont be cheap, expect to pay between $1000 and $1500 for a full tune - not just power, but a full map from idle.
Whilst this isnt cheap, it is quite good value for a japanese tuning guru to come over and get the best possible safe performance from your car.
Numbers available, currently need 5 cars to make it worth while for the tuner to come out - air fairs hotel accomodation etc.
currently 3 spots are pretty much spoken for
Anyway guys, please put the word out, I would really love to see what these guys can do with my car - this is pretty close to a once in a lifetime opportunity.
Hey Man, put me down on your list, i have a fussy bit at the top of my rev range no-one seems to be able to get rid off! I have no problem paying as long as i get a wicked tune! :aroused:
I wonder who I sent it to then?????? Sent one seconds after my last post on this thread?
I actually have bad news. Signal are going to be busy around mid May - just found out today:( I checked with James, and he is negotiating for another date, but he doesnt want to commit until it is confirmed - shouldnt be too long though.
I will definately let you know as soon as its confirmed.
Oh that sucks...........hopefully not to long
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
