Ok so my problem is i was driving my 34 GTT like a week ago and the RPM and Speedo started showing 9000 rpm and 180plus km while i was doing less then 50kmph and under 2000rpm. Then it went back to normal.
So today it decied to do the same thing but only the water temp started aswell as digital km trip meter. But then they all froze half way and then dropped to show zero on all gauges. So i stopped and turned the car off and back on and there still doing it. Then my engine light came on and stayed on.
My car is running fine not missing or anything. Can anyone help me out to what could be the problem or places to start looking?
https://www.sau.com.au/forums/topic/377071-r34-dash/
Well the problem first started after i put the larger turbo on. like 4 days after. Today it was on the dyno and had bigger injectors put in.
The dash in original and it never happened before the turbo was changed.
Edited by whitneybra
https://www.sau.com.au/forums/topic/377071-r34-dash/#findComment-6013678
what ecu are you using?
the ecu should tell you why the check engine light is on
but if the dash cluster is going spazzo it could be anything
given its only started since youve had work done
id say thats probably your souce
ie loose or shorted out wires etc
https://www.sau.com.au/forums/topic/377071-r34-dash/#findComment-6013682
    • Hi, wondering if the HKS bar and water reservoir still available? Thanks
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
