Therre was a ca/sr ecu that changed between sequential and batch, but considering the rb20 ecu only has 2 injector drivers it is batch only. No sure about ignition tho.
Pretty sure ignition is because you have 6 ignitors, if it was batch they would save money and use 2 or 3.
  • Replies 63
Not enough memory I guess the extra timing calculations would require alot more code CPU used has limited outputs
Im actually a programmer and one of my job was writing software for old processors, namely the same cpu used in these early boards. The code for writing to 2 outputs vs 6 and doing sequential vs batch is basically identical, the cpu still runs fast enough to process that many events. I can't see the CPU being the limiting factor, would have been something else but f**ked if I know what.
Funny enough I'm a programmer aswell yeah there wouldn't be a heap of extra code there is a bit of room available then again I've never worked on these chips they are probably faster than I give them credit for
You guys dont have a clue.
You realise in going to the haltech you will be batch firing injectors and coils! The std ECU is fully sequential on both. It will do everything about 100times better than the haltech ever will.
http://www.fueltech....pdfs/HalE6K.pdf
8 injector drivers as standard equipment
There is a reason haltech doesn't support the earlier ECU's anymore is beacuse they are shit.
You dont think it has something to do with the fact that the e6k is near on 10 yrs old now and used old technology, how many companies do you know of that keep producing things for 10yr old hardware when there goal is to always develop newer technology? Edited by W0rp3D
A bunch of programmers here haha.
Not a lot of additional code would be required to implement fully sequential injection/ignition. You basically just need slightly more sophisticated CAS decoder subroutine and cylinder counter and assign calculated outputs to different output ports based on that counter (using it as either input variable or index on inj/ign subroutine call). It's just one more routine and a couple of additional RAM values.
Those old CPU's are not very fast, but fast enough to handle engine management (some of early factory ECU's have hardware cap of 8000 rpm - been tested by Nistune developers, don't remember if RB20 is one of them). The only reason for not using fully sequential management I can think of is CPU may not have enough output ports.
Multiplexing can be a bit tricky in real-time applications like engine management. Requires some cleverly arranged synchronization.
On the other hand, it depends on how exactly CAS/load-calc-output data flow is implemented.
By the way I'm pretty sure I've read somewhere that R32 RB26 uses fully sequential management.
Neo motors use 16-bit processor, different family and higher performance. R34's use Mitsubishi 7700 processors, earlier Skyline ECUs use some kind of Motorola 8-bit clone manufactured by JECS, if I'm not mistaken.
EDIT: I mean I'm agreeing with you :) I'm just explaining why full seq. mode is easier for later ECUs
Edited by Legionnaire
Yep, much newer processor with more features.
Not necessarily so. The CPU itself may be the same/similar, but its peripheral devices can be very different - it's an ECU architecture thing. E.g. RB26 ECU may incorporate multiplexing/decoding logic you were talking about.
Sure, it is all speculation only. The best way to do it is to open ECU case and take a look what's in there. And assembly code would be handy also.
But I seriously think they are all sequential, otherwise they would use crank sync trigger instead of CAS.
By the way 16-bit processors are seriously faster than 8-bit in this particular case because all AFM values and load calculations use 16-bit arithmetic.
  • 4 weeks later...
Hey I was wondering what ecu would be better for my setup mods are
Td06h-20g 8cm housing
550 injectors
3 inch exhaust
35 mm turbosmart external wastegate 17 psi
Stainless high mount
32 gtr cooler
I know nistune will be cheaper but lets put price aside on this one
so which one did you go with?
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
    • wedding eh.....I seem to get to more funerals than weddings or christenings these days....
