Therre was a ca/sr ecu that changed between sequential and batch, but considering the rb20 ecu only has 2 injector drivers it is batch only. No sure about ignition tho.
Pretty sure ignition is because you have 6 ignitors, if it was batch they would save money and use 2 or 3.
  • Replies 63
Not enough memory I guess the extra timing calculations would require alot more code CPU used has limited outputs
Im actually a programmer and one of my job was writing software for old processors, namely the same cpu used in these early boards. The code for writing to 2 outputs vs 6 and doing sequential vs batch is basically identical, the cpu still runs fast enough to process that many events. I can't see the CPU being the limiting factor, would have been something else but f**ked if I know what.
Funny enough I'm a programmer aswell yeah there wouldn't be a heap of extra code there is a bit of room available then again I've never worked on these chips they are probably faster than I give them credit for
You guys dont have a clue.
You realise in going to the haltech you will be batch firing injectors and coils! The std ECU is fully sequential on both. It will do everything about 100times better than the haltech ever will.
http://www.fueltech....pdfs/HalE6K.pdf
8 injector drivers as standard equipment
There is a reason haltech doesn't support the earlier ECU's anymore is beacuse they are shit.
You dont think it has something to do with the fact that the e6k is near on 10 yrs old now and used old technology, how many companies do you know of that keep producing things for 10yr old hardware when there goal is to always develop newer technology? Edited by W0rp3D
A bunch of programmers here haha.
Not a lot of additional code would be required to implement fully sequential injection/ignition. You basically just need slightly more sophisticated CAS decoder subroutine and cylinder counter and assign calculated outputs to different output ports based on that counter (using it as either input variable or index on inj/ign subroutine call). It's just one more routine and a couple of additional RAM values.
Those old CPU's are not very fast, but fast enough to handle engine management (some of early factory ECU's have hardware cap of 8000 rpm - been tested by Nistune developers, don't remember if RB20 is one of them). The only reason for not using fully sequential management I can think of is CPU may not have enough output ports.
Multiplexing can be a bit tricky in real-time applications like engine management. Requires some cleverly arranged synchronization.
On the other hand, it depends on how exactly CAS/load-calc-output data flow is implemented.
By the way I'm pretty sure I've read somewhere that R32 RB26 uses fully sequential management.
Neo motors use 16-bit processor, different family and higher performance. R34's use Mitsubishi 7700 processors, earlier Skyline ECUs use some kind of Motorola 8-bit clone manufactured by JECS, if I'm not mistaken.
EDIT: I mean I'm agreeing with you :) I'm just explaining why full seq. mode is easier for later ECUs
Edited by Legionnaire
Yep, much newer processor with more features.
Not necessarily so. The CPU itself may be the same/similar, but its peripheral devices can be very different - it's an ECU architecture thing. E.g. RB26 ECU may incorporate multiplexing/decoding logic you were talking about.
Sure, it is all speculation only. The best way to do it is to open ECU case and take a look what's in there. And assembly code would be handy also.
But I seriously think they are all sequential, otherwise they would use crank sync trigger instead of CAS.
By the way 16-bit processors are seriously faster than 8-bit in this particular case because all AFM values and load calculations use 16-bit arithmetic.
  • 4 weeks later...
Hey I was wondering what ecu would be better for my setup mods are
Td06h-20g 8cm housing
550 injectors
3 inch exhaust
35 mm turbosmart external wastegate 17 psi
Stainless high mount
32 gtr cooler
I know nistune will be cheaper but lets put price aside on this one
so which one did you go with?
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
