ITEM: GTR Trust/GReddy Drag Intercooler 710x165x305mm with sssingle 80mm inlet & 100mm outlet end tanks with a polished finish
CONDITION: AS NEW & UNUSED
PRICE: Worth over $3,000 new - selling for $2,500
PAYMENT: Cash on pick up or direct deposit - postage extra
CONTACT:I here or via PM
OTHER: This is the biggest and baddest GTR cooler around. As seen on many huge HP GTR's.
NO TIMEWASTERS OR LOWBALLERS
Has probably had minimal use if any or just been used for mock up/test fitting and been decided it would not be suitable or something along those lines.
I have never questioned NXTIME's description of parts he's always selling high end and quality parts. I wouldn't doubt the quality of this cooler.
Free Bump
Thanks, Weapon.
OK, just to be absolutely clear. This cooler has never been used, test fitted, or otherwise and is NEW and UNUSED but does not have the original box and is therefore described as being "as new" because that is excatly what it is.
Got it? Or do I need to draw a pic?? :D :D :D
Now... :iluvff: where are all the serious buyers?
  • 3 weeks later...
$2,500 is what I am asking :)
It can fit all GTR's. It may need some trimming to fit the R32 or the R34. However, I don't think that it will be anything major as these were made to suit GTR's.
