Some of these guys are running 160mph+ in street cars man...
i know this, supra forums vids n youtube r my best friend lol
they even do it in fullweight cars, 28x9 or 10.5 slick "with" IRS and H-pattern stock 6 speed box
alot of them were running the garrett gt47-88 but not alot are leaning towards the precision 7175 and 80mm range turbos
and thanks pj, were i get htis 6766 bolted up ill let the figures speak for themselves, i dont see why it wont make 700whp on conservative boost and e85
  • 9 months later...
my brother has a 62XX on his r34 GTR
made an easy 350kw on 98 with 20psi... we didnt push further on 98 as the bottom end is stock
currently sitting on 420kw with 21psi... this was with 65% ethanol in the tank... its up to 84% now so will be going back on the dyno and pumping another 5-8psi through it.. should crack 450kw quite comfortably. Turbo can definitely make 500kw on e85 but the motor is stock so I don't think its going to get pushed that far
in terms of response... from my personal experience I wouldn't exactly call it street friendly.
There is definitely lag... I don't see positive PSI until 3.5K ish RPM... compare that to my -9 where i've got 5psi by 2.5K ish....
Although once 4.5K RPM comes around all hell breaks loose... they pick up boost so quick so the power delivery is just one big rush...
its a mental setup... but if i was to do it on mine I'd go one size smaller so I could feel some boost during daily driving...
the cam gears still need to be adjusted so lag will come down a bit
Edited by usmair
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
