Maybe just my bias but I reckon the V36/G37 looks a hell of a lot classier. Hyundai has certainly come along way from the little Excels and Sonatas in the 90s but the Genesis coupe still looks very Tiburon to me. Interestingly I have read and watched a number of road test comparisons between the 2 cars and the reviewers tend to agree that the V36/G37 is undoubtedly a better package but the Genesis is unbeatable bang for buck...
Yeah, they do look similar. :P
I still won't buy a sport car in Hyundai though as it still has a long long way to match any Japanese competitors in performance, longevity, not much supporting aftermarket parts and resale market / value.
It's a good value for money though for those who want a cheaper sport car and not wanting a Japanese sport car. :)
Edited by VNS 24
Hyundai have come a hell of a long way and the Genesis does look hot. They compare them to the G37 Coupe in the states and there is generally not much in it at all.
Hyundai's only problem, I think, is lack of racing pedigree. Most of the more fancied car manufacturers that they would like to try to go up against (NISSAN, Mazda, BMW etc etc) all have at least some history in MAJOR motorsport, as far as I am aware Hyundai do not. They were in Rally for a while, they even talked up getting into F1 when Korea got their own GP, but it never happened......
When you start out making $10,000 s&%t boxes, you are always going to have trouble working your way up to the high end. I guarantee that Hyundai will be making some rediculously nice, high end cars in the near future that are easy as good, if not better, than their competitors but the simple fact is that once you have a reputation it takes a looooong time to change it.
IMO i rekon the genesis looks better than the V36. no offence intended to anyone, thats just MY personal opinion.
i still dont think id buy a hyundai after them making complete shitboxes. but as craig has mentioned, read how they wanted to run the company.
their new in-house 5L V8 is a monster though
They way they both look is always a taste thing...
But at the end of the day the Skyline is finished off better and is quicker and is less likely to leave your forehead indented into a 100 ft gum tree!
The Genesis got a gong in my Top Ten Cars We Never Got article - copy and paste...
Hyundai, in a rare stroke of brilliance, decided to make the Genesis rear wheel drive. Care to name an affordable Japanese RWD sports car released in the last ten years? No? Neither can we. Then there are the engines: there’s a two-litre 4 cylinder turbo engine producing 157kW, which sounds a bit pathetic until you realise that its bottom end is shared with the Mitsubishi Evo, but with even more strengthening measures taken. If there was ever a motor screaming out for 25psi worth of boost, this one is it. Then there’s the rorty 3.8 litre V6 atmo engine pumping out 228kW, widely considered to be a worthy adversary to the VQ37 engines in the 370Z. Still not enough? The sedan has a 4.6 litre 287kW V8 stuffed under the bonnet, and rumours have persisted that this motor will eventually make its way into the coupe, although whether it would upset the coupe’s balance is anyone’s guess. Add Brembo brakes, a Torsen LSD and a six-speed manual in a neatly styled car that undercuts its rivals on price by a good margin, and you have a winner on your hands. The Genesis has genuine street cred in the US too: Rhys Millen was the first to jump on board, building a 550ps Genesis drift car for the Formula Drift series with the V6 engine taken out to 4.1 litres and a Turbonetics huffer, closely followed by HKS USA who built a show car based around the 2.0 litre engine with a GT2835 bolted on.
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
