Series 2 Stagea C34 RS4, Built 2000
Rego until Jan-2012
Silver in Colour
Driven daily by my wife with the kids
Last dyno was at 255hp at the rear wheels. Has now been fitted with z32 and nistune since then. I have a tune on there that was on another stagea tuned for 14psi.
No accident history
Location – Ipswich, QLD
Price - $17,000 ono (no stupid offers please, I also reserve the right not the sell the car with the carputer installed)
No Time Waster Please - Serious Buyers Only
Looking at maybe a VZ commodore sedan or wagon plus cash my way if someone is interested in swaps.
Contact – Curt 0430 104 668 or [email protected]
Engine
· RB25DET Neo Engine with 115,xxxks
· 100k service done
· Greddy Blow off Valve in stock position
· HPI FMIC from Just Jap with Stainless Piping
· Full HKS GTRS Turbo kit with stainless braded lines
· Z32 AFM
· Apexi Air Filter
· Malpassi Fuel pressure regulator
· 500hp Walbro intank fuel pump
· HKS Dump pipe with custom intermediate pipe
· 3" x-Force cat
· 3" Apexi silent power II cat back exhaust
· Just serviced with Penrite HPR15 oil
Drivetrain
· Gearbox valve body has been upgraded to stage 3. (very nice and smooth to drive in Auto mode, whilst in tiptronic it shifts quick and tightly.)
· Semi Auto Tipronic
· R33 GTS-T 4pot front and 2pot rear Calipers Fitted (rear Stainless Braided lines fitted aswell)
· Brand new Slotted rotors fitted
· Tein super street suspension with adjustable ride height, dampening, and rebound. From Fulcrum
· Stagea Strut Brace Front
· New Swaybar links Fitted
Exterior
· Custom towbar fitted.
· Avanti 18" wheels and tyres
· Clear Side Indicators
· LED parker Lights
· LED number plate lights
· Dual Sunroofs working perfectly and no leaking
· Tinted front Windows and Sunroofs
Interior
· Apexi Boost Gauge (in Bar )
· Apexi Turbo Timer
· Greddy Profec B II boost Controller (7psi and 14 psi settings)
· Nistune Programmable ECU with licensed software
· LED interior lights (great at night time)
· Air con works really well, new bulbs fitted to dash panel
· Stagea Floor Mats
· Still has Nissan Car Security that Still works, comes with funky remote for remote starting J
· Rear cargo cover (pull from behind seats to rear gate to cover item in the boot, leather)
· Carputer Installed – will be included with the car at the right price
7" in dash Touchscreen LCD (Lilliput)
Intel Atom 1.6 GHZ dual core
2gb Ram
32GB Kingston SSD
XP Lite
Centrafuse 3.1 Frontend
GPS
Music
Videos
Bluetooth Phone
Nistune Software
Nissan Datascan
Nissan Gauges (gtr style)
Rear 7 " Monitor (USB Powered only)
2ch 500w AMP for front speakers
4ch 900w rockford fosgate amp for 12" sub
https://www.sau.com.au/forums/topic/377889-s2-stagea-rs4-neo-gtr-s-z32-nistune/
  • Replies 43
  • 3 weeks later...
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
