Hey guys, so i have a 1994 model s14 forsale.....only reason for selling is a change in direction of hobbies for a while.....if i can't get around the price i wanted i will just put it in my parents shed and keep it for later....
100% defect free
Can come with rego
Can come with blueslip
it is out of rego atm though.
Make it your track weapon, or if you got the minerals, drive it on the street like i did ;D
I will try my best to get pics up today>
Either way, list of gear that will come with car....
13xxxx on shell
1994 s14a shell, with s2 face lift
The car is a dark purple (will see in pics)
dmax widebody (moulded)
weds? 18x10.5 -9 ® 18x9.5 -11 (f) (they look like work vs-xx) (some gutter rash, ive been "told" all repairable)
slotted front rotors
BC coilovers, less then 1000km travelled
Has a couple of rear adjustable arms (JJR)
Front strutbrace
Battery is brand new, relocated to boot, all new terminals.
Brand new Deastchwerks 300lph intank pump (new relay and power pick up from boot, 0 voltage drop)
Alpine headunit
sound stream 6x9s
sound stream splits up front
fusion 4 channel 600w amp
s15 front and rear leather seats,
s15 steeringwheel
nismo gearknob
boost/oil pressure gauges
ABS has been deleted
Custom gearbox mount to suit rb25 gearbox
Custom tailshaft to suit rb25 gearbox
Custom bracket for clutch master so pedal feel is absolutely perfect. (no conversion woes)
r33 crossmember
r33 engine mounts
r33 clutch master cylinder
r32 gtr clutch slave cylinder (with braided line)
Full 3 inch dump/front to suit this set up, 3 inch cat, 3 inch cat back with a twin tip (i think xforce) muffler.....it is pretty loud im not going to lie...but you can keep it quiet if you know how to drive.
Nothing in this section will be seperated.
Car is also wired,so pretty much, get your motor, a z32, a powerfc, you can tune the car, it will start as soon as you plug it all in.
Located in Narellan NSW 2567
Price: im going to say $10000 everything above this line purely as a ballpark figure so thread doesnt get locked
_________________________________________________________________________________________________________________________________________
now i have alot of "extras" so to speak..
If you are interested in the car, you will most likely be interested in alot of these....
genuine greddy plenum (less then 1000km)
6boost highmount manifold (less then 1000km)
genuine garrett 3076r .82 rear housing (less then 1000km)
turbosmart 50mm progate (less then 1000km)
turbosmart bov (unsure of model, can be plumbed back though)
turbosmart FPR 800 fuel pressure reg (with braided line) (less then 1000km)
custom polished fuel rail to suit top feed injectors onto greddy plenum (with braided line)
700cc SARD top feed injectors
apexi powerfc with handcontroller
z32 afm with plug
full aluminium intercooling piping kit, all custom to suit
4 inch aluminium custom intake pipe
custom polished catchcan with hidden breather
ebay 52mm alloy radiator (less then 1000km)
Twin 12 inch thermos (less then 1000km)
small alloy overflow bottle
Justjap intercooler core (600x300x76) (less then 1000km)
rb26 rockercovers powder coated in wrinkle black (includes clear timing cover with hole drilled out to fit VCT)
Now as the car is still running, this isnt going to be ready to be parted this weekend....it probably wont be ready until next month.
I will only part it once i have recieved a decent deposit for the rolling shell. Obviously the buyer of the shell would be interested in alot of the smaller parts as this would make life very easy.
Im hoping mods will just let me list the extras without prices, as i dont want to put prices yet, as i wont have the items off for some time. I would like to give the shell buyer preference also.
Im going to try my best to get pics up this morning. If not, PM me your phone number and i will sms you any picture you would like..
Cheers for your time
Aiden
Edited by soturi
https://www.sau.com.au/forums/topic/378100-eoi-s14-100-ready-for-rb25/
  • 2 months later...
  • 3 weeks later...
Yeah it was for an r32 gtr - twin core>
genuine greddy plenum (less then 1000km) $1100
6boost highmount manifold (less then 1000km) $950
genuine garrett 3076r .82 rear housing (less then 1000km) $1500
turbosmart 50mm progate (less then 1000km) $600
turbosmart bov $225
turbosmart FPR 800 fuel pressure reg (with braided line) (less then 1000km) $200
custom polished fuel rail to suit top feed injectors onto greddy plenum (with braided line) $150
700cc SARD top feed injectors $600
custom polished catchcan with hidden breather $200
ebay 52mm alloy radiator twin core (less then 1000km) $150
Twin 12 inch thermos (less then 1000km) $100
small alloy overflow bottle $50
rb26 rockercovers powder coated in wrinkle black (includes clear timing cover with hole drilled out to fit VCT) $300
I think the prices are pretty fair, pics up soonish
pm meeeeeeeee
Pick up in arncliffe area preferred
Will you be interested in packing it and dispatching it to WA? IE if your work uses many couriers or freight companies. I could organise for it to be picked up directly as long as you packed it. Is the manifold a standard T3? once I get my car back from the shop with there diagnosis I'll send you a message and see if you still have it. PM me if you want.
regards
Chris
    • Hello Liam - HA - somewhere in flies - possibly I have an update, but I have been so busy, projects have taken a back seat to getting business back on track.  I will let you know the outcome, but I think I am going to go for the 8HP,  CHEERS.  ELVIS
    • Thanks Joshuaho96, yes - as someone else also suggested, the 8HP seems the 'smart choice' - HA - and ZERO to do with cost, but I am sure 8 speeds will be better than 6 speeds - HA - maybe.  I will purchase a new 8HP,  Thanks.  ELVIS.
    • Nobody said anything about getting a "...cheap Falcon box..."- it was JUST a question about a specific transmission.  And YOU may have a problem with not enough $ - HA - I do NOT - so please keep your comments like you are some financial guru to yourself.  BUT - much appreciated re the cost of a new 8HP and I twill probably be the way I go.  Thanks.  ELVIS.
    • Most people I know in the BMW world are swapping 6HPs for 8HPs. The 6HP has a big issue with one of the clutch drum bushings wearing out shockingly early which leads to them going into limp mode going into 5th/6th gear as the oil pressure loss from the worn bushing causes clutch slip. Even with the adaptations in shifting the TCU can't bump line pressure enough to keep the clutches from slipping and burning. I've personally looked at a 335d with 6HP28 with one owner and ~90k miles on it and the transmission adaptations were way out of spec and even though it nominally drove ok I'm confident it would have needed a full rebuild sooner than later. Other than that they're fine, but the 8HP doesn't really have weird issues like this to my knowledge and they're in everything these days so pulling them out of crashed cars isn't too hard.
    • There is an ABS pump and a few solenoids. You could trigger the front/rear solenoids with a pressure bleeder attached with a Consult 2.
