Hi,
Tried this in the maintenance forum but got no responses, so here go. I have a few questions regarding headlights on the R32, specifically the GT-R:
* Are the headlights the same across the R32 range?
* I understand there are two different types of R32 headlights: one fitted to earlier cars, one to later cars. Is this correct?
* Does anyone have measurements for the lights?
* Can anyone provide close up pictures of the two types?
* Better yet, does anyone have pictures of the headlights with the glass front removed?
Thanks,
Lucien.
https://www.sau.com.au/forums/topic/37813-r32-headlight-questions/
  • Replies 99
i think only the 89 model had different lights cos the front indicaters were clear not orange. so that is maybe why they changed the actually head light cos of the different design or something.. thats about all i got.
GTR headlights changed slightly in wattage in 1991, other than that it should be the same for the GTR. THe GTSt's changed all over the place, but not the GTR.
Wattage doesn't really bother me, I am more interested in changes to the reflectors, projectors, etc, etc (ie. the construction of the headlight) :D
LW.
you're thinking N1 headlights anfd GTR headlights... I guess they're both GTR's but N1 headlights are a lot more expensive and rarer. Two Square = N1, Square + Round = GTR.
There's a lot of Square + Rounded Square goin around which are 1989 pov pack headlights off Type G's. A lot of people think these are N1 but they're not.
the only difference between the GTR ones and the rest of em is the clip for the nosepiece that goes inbetween the bonnet and the bumper. So if you tried to fit GTS/t ones you could on a GTR (the brackets to mount it are all the same) but you won't be able to put your nose thingy on.
Not really 2 square ones, but it has a higher intensity inner bulb and was only available on race equipped GTR's (which had the N1 spec RB26DETT). Also back light takes up the entire headlight, and the inner light sits on top of it.
R32 headlights with no ring on the "projector"
R32 headlights with the ring on the projector
Very similar to the N1, cept that it used low power bulbs and the back light takes up half the headlight only.
And these are a set of aftermarket headlights that I'm getting :rofl:
god knows, they seem to pop up on a couple of drift spec r32's, still trying to find out who manufactures them... they're basically the same globes but mounted on the outside withouta glass cover... the one above the last one is the same headlight close up...
that explains why my headlights are slightly different... left has the ring & right is like the one with 208 next to it.
despite the slight differences in design they both have the same intesity & beam spread on my car.
Do you have pictures of the clip in question... ?
LW.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
