My car was stolen a few weeks ago and I was fortunate enough to have it found a few suburbs away. A few bits and pieces were stolen including a Dual Stage boost controller and my SAFC. Since the car was stolen when i try to drive/rev the car it splatters at about 2000-2500 revs. At first I thought that it was the hoses that were left hanging from where the boost controller once was then i reconnected them but the problem remained. Since then I thought they could have boosted it too high and stuffed my turbo then i thought of the BOV and also the wiring to the ecu(its practically hanging on the ground now). But last night i thought about my spark plugs. I had an order placed through NGK for suitable iridiums for my RB25DET and they sent me 1.1mm gaps which I was pretty sure was wrong but they worked when i put them in so i left it like that. When the SAFC was taken out because the fine tuning was gone could that in conjunction with the spark plugs have caused the problem???
Or are there any other ideas
(Air exits back through the pod filter i think because the valve on the BOV hasnt had enough force to open it.)
https://www.sau.com.au/forums/topic/37814-rb25det-splattering-please-help/
Sounds like the car may be in 'limp home mode'. this could be due to a fualty connection coming out of the ecu, AFM not plugged in or working properly or a few other things.
check your afm connection, check the ecu is plugged in properly, check none of the wires from the SAFC being disconnected are causing an earth. make sure all the hoses are plugged in. then do an ecu reset.
If all this fails to rectify the problem, run ECU diagnostics, which may shed light on the problem.
1.1mm gaps with the stock coils aren't real boost-friendly, but shouldn't be causing problems at 2500rpm. A stuffed turbo shouldn't cause the problems you describe either.
Things I can think of:
1) Bad tuning (possibly due to parts being taken off), which is unlikely unless you have different cams or something because without the SAFC it'd just be running the stock maps
2) You've missed some of the pipework or a hose has popped off somewhere
3) Some of the wires going to the ECU are either disconnected, or are shorting out. Quite likely as they would not have been particularly careful when removing the SAFC and, as you say, your loom is 'hanging on the ground'
When you say that it 'slatters at 2000-2500 revs', do you mean it won't go past there, or it's a mess from there on, or that there's a bad spot about then which clears up for the rest of the rpm range?
Disconnect the battery, and either leave it overnight, or stand on the brakes for (to be safe) 30 sec or so. Reconnect the battery, and voila, your ECU has forgotten all its 'tweaks' that applied when the SAFC was connected.
The exact same thing happened to me about a year ago. You need to rewire(return the wiring to its original configuration) the ecu, or remove the wire remining from the safc. Your standard ecu still thinks the safc is connected and hence the dodgy signals being sent to the ecu. Unfortunatley i cant tell you exactly how to do this because i had my mechanic fix the problem at the time.
The reason why the car is spluttering so hard is because your ecu is overfueling the engine.
Hope this helps,
Jason
the AFM wire on the ecu is cut when installing a SAFC, to intercept and adjust it, it is not spliced like the rest. Have you shorted the AFM wires together after the SAFC was stolen? If not, then your ECU thinks your AFM is not connected / fubar so it is in limp home mode.
I'd be taking it to an auto electrician to have them check the wiring loom near the ECU out, rather than have you mechanic do it. I have no idea how good/bad/otherwise your mechanic is, but for electrical problems, particularly if they aren't familiar with the car, I would always take it to a leccy.
CroatianR33, Zahos is right.
It's DEFINITELY because of the AFM wire was cut for the signal to be routed into SAFC and out again to your ECU. Since your SAFC is stolen, that wire is now disconnected/left open. Find the installation diagram of your SAFC to find out which wire was cut, reconnect both ends of that wire and it will solve your problem.
    • Hi, i’m making Vag coil loom for rb25det, can anyone confirm the wire guage i’m using for power supply in diagram is enough for supply not too small for loom? For earth do i need to follow the same procedure or i can use only 16awg wire for all coil and their connecting wire following to the plug?
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
    • I haven't knocked them down yet. I think I made the repair more complex than it should have been. I had rock chips combined with waviness and dents and I tackled it all in one because it was near each other and just end up wasting a bunch of bog lol. I'll knock down those areas and see how I go. And yep what you are saying at the end is correct. I think I might be sanding the top of a steep hill then my sanding block falls into the dent and gets rid of the guidecoat if that makes sense. Though shouldnt unless I'm covering too big of an area with not a long enough block. I'll try something new and provide some updates. Getting there though! Thanks as always.
    • Yeah makes sense, hard to comment on your situation without seeing what your doing. I was talking generally before, I would not be looking to randomly create low spots with a hammer to then have to fill them.  It's hard without seeing what your doing, it sounds like you are using the guide coat to identify low spots, as you're saying the panel is still wavy. I don't see how you're not ending up with patches of guide coat remaining in a wavy panel? Once the high spots are knocked down to the correct level, surely to have a wavy panel you need low spots. And those low spots would have guide coat still in them?
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
