Hey guys as the topic says I am looking at getting my very first skyline, I am probally gonna get a 32 GTST or GTS4. or mabye a 33 GTS-t. I just wanna know what sorta price is good for these, and anything major that could be wrong with it that I should look for. also any good places in brisbane that you know are good dealers to buy off. thanks alot, help much appreciated
https://www.sau.com.au/forums/topic/37818-buying-my-first-skline-d/
i think that R32 parts are very easy to find and some parts from a RB25, RB26, and a RB30 will fit onto the RB20. i have a new water pump that is meant to be on a RB30.. the RB series engine have pretty much the same bottem end.. well maybe some minor things but nothing to be worried about.
it depends on what shape skylines YOU!!!!!!!!!! like the best. i got a R32 GTS4 because i like the r32 better than the R33. but thats just me. one other thing to think about is that the R33 has a better engine and gearbox than the R32's have.
depends where you go. I have never had problems with parts for mine.
in saying that though, I'm in sydney, not sure about melbourne. shame too, I am selling mine now and its a nice one that I haven't "thrashed" its a 93 model.
I have been to the track 3 times but never over done it, never been drag racing either. as much as you might think it silly, I respect my car and don't want to kill it doing stupid things.
mark
    • They are, a good friend of mine bought one to replace his blow factory turbo, running a Toshi Tune reflash. Just use their supplied water/oil lines and you're good to go. At the time, they were like $900 delivered.
    • This is an option for 100% bolt on, the GCG high flow -  https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html Also, I'm pretty sure hypergear does a high flow that is 100% bolt on, it just doesn't make as much power as their bigger high flows.  Even if you get a hypergear turbo that requires you to chance the intake piping, it is a really simple modification. It can be as simple as a piece of silicon hose and you pop a filter on the end. It doesn't have to be some crazy pie cut titanium work of art intake pipe.  If you have the ability to swap the turbo yourself, you would be able to sort the intake piping out.
    • Just as a thought, if it's in neutral, thats your drive line disconnect, not the clutch. Clutch slip at the dyno with pedal fully out, is actually adding a second disconnect. So it's not a clutch issue if you're in neutral. Just a bit of friction dragging the output around while in the air.
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
