R33 gtst parts
Veilside front bumper, white, no cracks $200
Veilside rear bumper, white $200
D-speed side skirts, white $200
boot lid, needs paint $50
tail light LHS $40
pair of tail lights $80
custom clear tail lights $200
X2 air con compressors $50 each
climate control unit $50
heaterbox, has core still in it $50
autometer A-pillar dual gauge holder, fits 52mm gauges $50
stock RB25 cams $50
stock RB25 exhaust manifold $20
3inch front pipe, will work with stock dump pipe $50
180sx parts
pair of rear calipers $20
pair of rear rotors $20
6 bolt driveshafts $50
roof lining $20
seat belts $20
glove box $20
centre air vent $20
side air vents $10
digital climate control $50
Parts are in Camperdown VIC
0439884027 Jake
https://www.sau.com.au/forums/topic/378424-help-my-clean-out-my-shed-sale/
  • 2 months later...
unopen bottle of Castrol SRF brake fluid. 1ltr $150
r33 rb25 engine damper kit. $50
r33 rb25 exhaust valves. removed from a running motor. done 127000kms $100
r33 rb25 intake valves. $100
Hybird intercooler, tube and fin core, 600x300x76mm, cool condition $100
180sx manual tailshaft. $100
Turbosmart boost tee, $50
R32 RB20DET Gearbox with shifter. $550
2inch, Autogauge boost gauge. new $50
  • 1 month later...
Juran sandwich plate. can be used for oil pressure and oil temp. $50
RB25 Cam gear backing plate. $10
RB25DET crossover pipe $20
R33 GTS-t throttle cable $20
  • 4 weeks later...
  • 1 month later...
  • 4 weeks later...
  • 1 month later...
  • 3 weeks later...
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
