One of my wheels is buckled, so need a replacement
am after the front wheel (6.5" wide) in good nick, no gutter rash, dont need a tyre with it
WTP around $50, depending on condition.
Please pm me/reply if you have one
If you have a pair and really don't want to seperate them then still let me know
Thanks
Richard
https://www.sau.com.au/forums/topic/379127-syd-wtb-1xr33-gtst-stock-wheel/
  • 1 month later...
Had a search but must of missed out, only saw your post now. For some reason I'm not getting email notifications when my threads get replies, only for PMs.
Sooo still need a stock wheel in good condition and preferably with good amount (not necessarily quality) of rubber. If anyone has one please send me a pic thanks!
