Hey All,
As everyone probably knows, I'm wrecking my R33 GTST, after it's little roll. Have been away so haven't had time to do much with it till now;
Bits that have been sold:
Exhaust
Rear bumper
some dash parts
floor mats\ash tray
injectors
afm
ecu
Engine\gearbox have been spoken for but waiting to finalise to may be up for sale again later.
Bits that are damaged:
lower control arm LHS
windscreen
no front bar
radiator\clutch fan etc
Extra parts for sale:
Brand new KYB gas shocks to suit R33 GTST, front and back.
Jim Berry 4000lb full monty clutch to suit R33 GTST
R33 stock LSD
Black front bar, has some damage "mspec"
Please let me know if you are after anything\need anymore info on what's in it etc.
Email: [email protected]
Mobile: 0407884138
https://www.sau.com.au/forums/topic/379163-wrecking-r33-gtst-series-15-1995/
Hi mate,
after prices on the following if u still have it:
rear sill panel or just the speaker covers
RHS window control switch & Surround
RHS interior door opener surround
RHS & LHS plastic guard liners
Front & Rear wiper arms
RHS front seat or pair
Center Console Rear section
Boot trims/carpet
Cheers mate
Smithy
0447 527 480
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
