Hi guys,
I am wanting to get a different BOV but i want the flutter sound valve not the typical whossshh. What are the names and models of any flutter sounding BOV's that you guys know of. And if any of you have one are you willing to swap for an HKS BOV?
your help is much appreciated,
Thanks
JL
https://www.sau.com.au/forums/topic/37919-bovs/
I never knew u could buy BOV's which make the flutter sound
ive got a factory bov with an fmic and i get the flutter....pretty sure its only the fmic which makes that noise
Or by removing something around your turbo so air hits it harder or against the wastegate ??? which creates the flutter...
https://www.sau.com.au/forums/topic/37919-bovs/#findComment-763682
shouldnt cause to much damage
thats same sort of principle for VLs when they wake on a cooler and get flutter
my turbo is still in good nick and thats running some high boost as well
but then again stock skyline turbos r made from pottery clay :-p so i wouldnt really risk it..
nick lets test it on urs :-)
https://www.sau.com.au/forums/topic/37919-bovs/#findComment-763750
Get a BOV, plumb it back, and get performance out of your car.
I think he's more concerned about the noise his car makes rather than the performance of the thing. :D
runnning no BOV hinders performance... u serious??? haha
Dead serious...... what are you laughing at?
:slap:
https://www.sau.com.au/forums/topic/37919-bovs/#findComment-763838
*sigh*
well from memory a BOV unless running high boost is not going to improve performance on anything... infact im pretty sure in one of my speed mags where they had a 4 page spread on them and what they do they are only designed to release pressure to extend the life of your turbo.
https://www.sau.com.au/forums/topic/37919-bovs/#findComment-763900
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
