hey guys need some technical advice , my car is puffing a bit of smoke on decceleration looks a greyish colour ,, my mechanic (i wont say who so their is no bias opinions) said it may be a valve stem seal? or turbo seals , does this sound right, or is he taking me for a ride? also is valve stem seals a big job? whats involved cheers
https://www.sau.com.au/forums/topic/379285-technical-advice/
yes could be either or oil rings.
coast down a hill in 3rd or 4th gear off the throttle using engine breaking and once at the bottom of the hill just floor it briefly. if it spews out oil smoke out the exhaust its a fair sign theres worn valve stem seals. to do the seals is generall a head off job.
yeah you can get a genuine VRS kit for 300 bucks ish. comes with all gaskets and valve stem seals and parts you'll need for head removal. then you'll need to have head machined 80-100 bucks, and labour + fluids/consumables to do it all 600 upwards so wont be cheap. but the flip side is your top end will be fresh again.
If I were to do that I would fit new guides too.
Which would be ~$400
Hence my $1000 thingy-ma-jig
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
