As per title,
I've decided to get some wheels spacers to fill out the gaurds on my gtr, since the standard wheels sit a bit too much in.
Im after that sorta flush - ish look, but dont know what spacers to get, that'll do the job. I know that the standard 33r wheels are 17x9 + 30.
Im not really too good when it comes to this sorta stuff. Thanks for all the help.
This is how my 33r sit now -
20mm for reasonably low like Ash's.
If yours is lower than that, 25-30mm.
i dont understand this reasoning, your saying if its lower get wider spacers..how come??
ED**oh wait this is a camber thing right??
Sorta.
Plus, if you lower than what height the GTR Ash have posted pic, 20mm will sunk further in hence wider spacer may be required (of course it all depends on what sort of look the OP want).
Also don't forgot, tyres are one thing you need to consider whether you want tucking in or sticking out - again depends on height of the car, camber etc etc.
Sorta.
Thanks for clearing that up dude, appreciate it, but im still a little confused
I dont really know how to get to what i want, I want that hella flush look, where the wheels and gaurds are as close as possible, and maybe a little wheel tuck?
If i was to use 25mm spacers, you think it'l do the trick?
how far are you looking to go? like this
for that look youll need at least 30mm spacers on the rears and maybe more like 40 on the front. then get some 195 tyres and some adjustable camber arms front and rear. and lower it like 3 inches. and roll your guards
It may do the trick, best for you to try and see how you feel.
I think your wasting your time going for the hellaflush look on stock wheels. Better to save the spacer money and hunt for new wheels
2c
Your right in that regards, actually me and another member on here were looking at a set of Rota's P45r 19x10 +20, for his r32 and my r33. He got them, but when i sold my old wheels that were on my gtr i didn't make as much as i thought i would. So i thought, i'll make it look decent for summer (by using the spacers) and spend my money on something else (looking for a e30 bmw convertible atm).
If only money grew on trees :(
  • 1 month later...
    • Just to be clear, there were no lights or codes when the hiccups were occurring. Also nothing noticeable in the cars' braking. It brakes fine and the dash is clear. I only made the connection when it did throw a code and suddenly, despite the lights, it felt great again.
    • Yeah they are sliders and this was in my head before I worked out it was the speed sensor.
    • Ok so we have a smoking gun.  A few weeks ago I had to replace a speed sensor that I'd fit incorrectly. I replaced the sensor and everything was fine with no lights or codes thrown any longer.  When I was doing some more bedding in yesterday I got ABS and traction control lights again and, considering when this happens those things are disabled, the pedal went back to normal with smooth braking and no hiccups.  The codes thrown are for the same speed sensor that I replaced. When I looked at the sensor I took out it looks like the tip of the sensor is damaged. So whatever happened to it, perhaps it has damaged the magnetic ring on the bearing (that I only replaced the other week). I'll get my boroscope in the hole where the sensor goes and see if there is any damage in there. Hopefully just the tip of the sensor is in there and the bearing is fine. 🤞🏻  It's worth noting also that the pedal hiccup happens more often and for longer periods now and totally goes away when the codes are thrown again which happens usually after 5 or so minutes of driving. Love all your help here as usual guys, thanks!
    • Could you put a real seat and harness in instead of what looks like leaving your passenger balancing on a milk crate
