I washed my car last thursday avo. The next night i went to my mates house and parked on a steep driveway. Half an hr later i went to get something out of the boot and noticed at puddle about 50cm near the back right corner of the car. I thought it might have been fuel but, noticed it was water. I then saw water dripping from the back bar.
Opened the boot to have a look around. Felt down behind the quarter panel to notice about 2inches of water sitting in there. I had some rust cut out of the wheel arch about 6 months ago. They also but some rust preventative in the quarter panel too. I dont think that is the cause of it.
Would it be ok if i drill a small hole in the bottom of the quarter panel at the wheel arch near the guard to let the water drain out?
The seal is coming out a bit on the top corner of the back window. Would that be the cause of the water getting in there? It would have to travel down the back pillar thru the chassis to get there.
I am not sure...
Does anybody know of a good window/window seal person in gold coast/bris southside?
The car is a 32 gtst.
Cheers
https://www.sau.com.au/forums/topic/37976-water-in-rear-quarter-panel/
I had a similar problem with water in the right rear quarter panel. I traced it back to a leaky tail light - they also half filled with water! I used a towel to wick away the moisture in the lights and then used some silicon sealent to seal the inside of the taillight unit. I also wicked the water from the quarter panel and since then I haven't had the problem happen again.
Do you have a 32? I think the tail light setup is different on a 33, thats all...
I havent really had a good chance to have a look at it yet. I suppose this super long weekend is a good time to sus it out.
Any windscreen place can fix your rear window seal......by the sound of it , the fool who did ur rust work has bogged/welded up your drain hole...all cars have them....check along the bottom of the seam where your inner quarter and outer quarter join(underneath) Something like this...
poke some wire up in there or carefully run a drill up one to clear it out....other than that drill from the inner guard as low as you can .....be care full tho, and remove the water first, like everyone else said....you dont want water running out of a freshly drilled hole into the electric drill your holding :zap:
Yeah I find that everytime I wash my car I rip off all the boot covers and dry out the puddles in my rear quarter panels plus where my space saver is.
I'll be taking the tail lights apart soon, and am looking at buying a tonne of silicon to make sure it doesn leak, but by the sounds of it if you do a search here and SDU it is a common problem for 33's and it a bugger of a job to fix up :)
Yeah I've got a 32. The tail light lens assembly is fitted by some sort of sealant and in mine there was a leak that allowed water to slowly get through.
I have a rubber pipe on the left side quarter of my car that drains water from *somewhere* in the bodywork.
My car has no rust otherwise.
T.
I'd check this first, it happened to me. Stick your head under the car and see if you can see the tube coming out, mine was inside the panel instead of poking through the whole. :)
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
