i have cai + catback, high flow car, coilpacks, good tyres already
my exhaust seems to slow the car down or do you think this is pretty quick for an NA
no one knows whats wrong with it its a 2.5" catback with no mufflers but it does have a resonator
it makes a bang sound from first to second gear
http://www.youtube.com/watch?v=wczannAfOo4&NR=1
https://www.sau.com.au/forums/topic/379806-flywheel/#findComment-6056345
It could definately use a little more power IMO, SAFC + tune will open it up a bit.
https://www.sau.com.au/forums/topic/379806-flywheel/#findComment-6056369
lightened flywheel often does bugger all for acceleration times, because while the car will speed up faster, it is also more prone to bogging down off the line. if you had a stupidly heavy flywheel you could fry the tyres by dumping the clutch at 1500rpm with bugger all throttle. if you have the worlds lightest flywheel (or no flywheel) you would nearly stall the car dumping the clutch while bouncing off the rev limiter if you had sticky tyres.
https://www.sau.com.au/forums/topic/379806-flywheel/#findComment-6056441
SAFC got me sweet FA in terms of power, got it tuned, got a tiny bit of torque mid range and thats it. Not worth it.
Ended up taking it out the next day and selling it for more than I bought it for.
https://www.sau.com.au/forums/topic/379806-flywheel/#findComment-6056522
Extractors, 2.5 inch system Highfloww cat and a boxed off Apexi pod filter.
This car http://www.skylinesaustralia.com/forums/topic/348709-r33-gts-build/
Hmmm no idea why it wouldn't increase power, i know of several of them used on NA 300ZX's and the gain was a good 10-15rwkw depending on the car. Hey nice car btw, diggin the 1/4 mile result :thumbsup: Thats the quickest NA liner i've seen :happy::banana:
https://www.sau.com.au/forums/topic/379806-flywheel/#findComment-6056621
higher dislacement thats why....
https://www.sau.com.au/forums/topic/379806-flywheel/#findComment-6057520
Safc that can only alter air fuel on a n/a skyline with mild bolt ones is fail in gain imho.
And err, that seems really slow considering you have some bolt ones too. I've been in a friend's na 34 auto and it was stocker (is completely stock).
Maybe get the health of the engine checked out and make sure timing is ok before trying to make it faster. Heck, if there's something wrong and it gets found and fixed it'll be faster anyways lol
https://www.sau.com.au/forums/topic/379806-flywheel/#findComment-6058478
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
