i have cai + catback, high flow car, coilpacks, good tyres already
my exhaust seems to slow the car down or do you think this is pretty quick for an NA
no one knows whats wrong with it its a 2.5" catback with no mufflers but it does have a resonator
it makes a bang sound from first to second gear
http://www.youtube.com/watch?v=wczannAfOo4&NR=1
https://www.sau.com.au/forums/topic/379806-flywheel/#findComment-6056345
It could definately use a little more power IMO, SAFC + tune will open it up a bit.
https://www.sau.com.au/forums/topic/379806-flywheel/#findComment-6056369
lightened flywheel often does bugger all for acceleration times, because while the car will speed up faster, it is also more prone to bogging down off the line. if you had a stupidly heavy flywheel you could fry the tyres by dumping the clutch at 1500rpm with bugger all throttle. if you have the worlds lightest flywheel (or no flywheel) you would nearly stall the car dumping the clutch while bouncing off the rev limiter if you had sticky tyres.
https://www.sau.com.au/forums/topic/379806-flywheel/#findComment-6056441
SAFC got me sweet FA in terms of power, got it tuned, got a tiny bit of torque mid range and thats it. Not worth it.
Ended up taking it out the next day and selling it for more than I bought it for.
https://www.sau.com.au/forums/topic/379806-flywheel/#findComment-6056522
Extractors, 2.5 inch system Highfloww cat and a boxed off Apexi pod filter.
This car http://www.skylinesaustralia.com/forums/topic/348709-r33-gts-build/
Hmmm no idea why it wouldn't increase power, i know of several of them used on NA 300ZX's and the gain was a good 10-15rwkw depending on the car. Hey nice car btw, diggin the 1/4 mile result :thumbsup: Thats the quickest NA liner i've seen :happy::banana:
https://www.sau.com.au/forums/topic/379806-flywheel/#findComment-6056621
higher dislacement thats why....
https://www.sau.com.au/forums/topic/379806-flywheel/#findComment-6057520
Safc that can only alter air fuel on a n/a skyline with mild bolt ones is fail in gain imho.
And err, that seems really slow considering you have some bolt ones too. I've been in a friend's na 34 auto and it was stocker (is completely stock).
Maybe get the health of the engine checked out and make sure timing is ok before trying to make it faster. Heck, if there's something wrong and it gets found and fixed it'll be faster anyways lol
https://www.sau.com.au/forums/topic/379806-flywheel/#findComment-6058478
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
    • To be fair it's the other way around. 300kw is boring in a modern Golf or BMW. They are so competent / well-engineered / devoid of emotion that you have to go stupid fast to feel anything. Whereas the <300kw RB still makes all the right noises and it feels good to drive. Can pull off at the lights with the turbo whooshing and the blow-off pssshing and feel like the coolest kid on the block. Just don't look to the side where you'll see the bored housewifes in their shitbox Yaris/Corolla/Camry that kept up because you didn't go fast at all
    • 300kW is so boring in a Skyline, you'll get spanked by someone's mum's Golf with Alibaba pipes, and an email tune.
