hey all i just bought a old mr30 skyline with a rb20det a few weeks ago. its a conversion with a supra gearbox t3 turbo with a big ass rear housing, front mount, external gate. boost tap, exhaust. its been driving fine untill up high no matter what the boost tap is set at the boost gauge is always pushing 14-16 psi and missfires. but last night i got in it turned the key the motor turns but wont start. i clutch started it and it ran fine then i turned the key off started it a minute later with the key it fired up, turned it back off waited ten minutes or so tried turning it again and wont start but the motor just keeps turning we checked the fuel line and im getting fuel past the fuel filter but beyond there i dont no. if anyone has any ideas on what it could be would greatly help im out of ideas. thanks all....
https://www.sau.com.au/forums/topic/379850-rb20det/
i tested the crank angle sensor i just pulled it out and turned it myself with the car on the reds and it sparked fine. would u think maybe the little teeth are stripped and its not turning inside the motor. i also ran over everything with a multimeter and im gettn power not a problem or should i start looking at the injector side of the problem.
https://www.sau.com.au/forums/topic/379850-rb20det/#findComment-6065206
If you can clutch start it and it runs fine, then you're most likely not going to have a problem with anything to do with your fuel or air systems, so I wouldn't waste time on your injectors. If one or more wasn't firing then it'd be misfiring like a mad bastard.
Sounds like a problem somewhere in the ignition system. Maybe the starter has crapped out (or maybe not getting enough voltage) and it's not spinning strong enough to engage the fly properly? It might sound like the engine is turning over properly, but could be not turning over fast/hard enough to actually start.
Have you done a voltage check yet? I'd start there. Make sure everything is getting enough battery power on start up. If it's started itself after running for 10 mins or so, then maybe the alternator has put enough kick back into the battery for it to give the starter motor the right voltage (which would be why it didn't start again after a brief on/off then sitting for ten minutes) OR the heat/vibrations in the engine has made a better contact on the starter motor connections.
https://www.sau.com.au/forums/topic/379850-rb20det/#findComment-6068418
im looking towards the ignitor all 6 pins dont look too well theres black lines showing and when i fiddled with it the car kicked over and drove started 2 more times now hasnt started since. im trying to get it to the auto elecs but its a bit of a nightmare trying to get it there but hopefuly getting another 1 will solve the problem ?
https://www.sau.com.au/forums/topic/379850-rb20det/#findComment-6082241
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
