Hey guys, I am selling some Denso 750cc injectors, they are brand new, am only selling them as I found some Nismo pink injectors at a great price and they are a better fit for my project than these. Am asking $550 for them, and will cover postage for the buyer or I'm in Kingswood Western Sydney if you want to pick up. Either PM me or SMS 0410761078.
Cheers.
Edited by cherring
https://www.sau.com.au/forums/topic/380113-denso-750cc-top-feed/
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
