G'Day,
Thought it was high time I pulled my finger out and dropped you all intro. :wavey:
My name is Jason O'Halloran (Racin Jason - the alter ego) and as most of you already know I'm the ANDRA Sport Compact Director.
Man where do I start,....nah stuff it you guys know all the good news/ bad news so far.
What a start to the official Sport Compact scene here in Australia!!
I would like to publically thank everyone who came and made all the Sport Compact events that have been held in the last 2 months so successful.
This is just the begining.....so the crowds were GOOD. The turnout of cars was GREAT. And the best bit is we have so much to look forward too. I take my hat off to you all, for with out the Tracks, the racers, the forums, the magazines,and the decent attitudes of people like NSW Premier Bob Carr - Sport Compact drag racing would be a pipe dream.
Kind of ironic the main politician behind the development of WSID has a name like Carr - maybe we can get him into a turbo RX-3 and pack him a change of jocks too!!!
OK so where now? We are currently revising the ANDRA Sport Compact rules, with the veiw to OZing them up a bit. They are suited more to the NHRA (USA) vehicles, and our vehicle demorgraphic is vastly different to our mates across the pond.
I see great development in the 'street tyre' classes, and the development of a seperate Sport AWD/4WD is definately on the drawing board. Minimum weights are also being checked, as they favour larger vehicles. They will now doubt be revised to suit the smaller/ older vehicles that Australia is renown for, ie RX3/ Datto 1200 etc.
Oh and we have a new logo about to be released as well!! It's the mutt's nuts to say the least - simple, techno, and very cool. More on that very soon!
Finally, I will try to check this site for any questions you may have, so feel free to ask away. If you want to go further, try the ANDRA website for more details....hell give me a buzz if you're really stuck.
I must say I love Sport Compact racing....not because I'm employed by ANDRA, but because I'm just a regular NOS sniffing, hi-flow spooling boost junkie like the rest of you. I know I'm going to make some enemies from the decisions I make, but they are all done in the best interests of the Sport.
Shit, if I make as many friends as I do enemies then life will be fine. So drop me a line.....after all I'm just speed lovin, nut bar like the rest of you.
Cheers for now
Just checked the website, specifically the ANDRA Affiliated Clubs section.
I've noticed that neither Sandown nor Calder are listed on your list of Drag tracks.
Now my two main questions are these:
Can we become an affiliate club, what do we have to do, what are the benefits and what are the costs?
And do you plan on including the above mentioned two raceways into your list of associated tracks, as the VIC chapter of SAU is very much interested in getting into the 1/4 mile drag scene (seeing as we now have a 617rwkw R33 GTR). We have members who are itching to do quarter mile drags but due to CAMS and costs of venue hire we're finding it extremely hard. Can you advice on anything we can do to make this reality?
Cheers,
Shan Moorthy
SAU VIC
Oh and here's a mugshot of Mr O'Halloran in case someone bumps into him on the street :D
lol...
any chance of reducing the size of that foto dude?
Not having ANDRA sanctioned events in those states sucks some serious type of arse. Come on, how long before they/you get your acts together?
Adrian
its a direct link off the andra website... i say fire your webdesigner (n hire me :D). I didn't think it'd be that large... yikes...
well I was trying to be more polite than that but yeah, how long till we get some ANDRA action?
lol well we need some sort of regulation, and besides the guys unning 10's do it in their own time. I was more concerned with getting the members more access to 1/4 drag comps etc.
  • 1 month later...
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
